* This utility is used to reset your "SESSION_WRITE_DIRECTORY" key after switching servers.
* 1. Make sure the DIR_FS_SQL_CACHE setting is correct in your /includes/configure.php file.
* 2. Copy this file to the folder where "index.php" exists for your Zen Cart site
* 3. Run it
* 4. The cache setting from your configure.php file will be displayed, followed by
* the cache setting from your database.
* If they match, it will say "No changes required."
* If they do not match, it will synchronize the database to match the configure.php setting.
* 5. VERY IMPORTANT .... WHEN DONE, DELETE THIS FILE FROM YOUR SERVER!!!!!!!!!!!
* If you don't delete it (or at least rename it to something very obscure), then you run the
* risk of somebody using it to find out information about your server configuration, which
* could compromise your site's security. Thus, deleting this file when finished is the best approach.
