Results 1 to 9 of 9
    May 2007
    Default attributes separate stock-need inventory help!
    I have added "attributes separate stock" and I am pleased with what it allows me to do. However, I cannot get it to enforce the inventory I have.
    Let's say, for instance, that I have 39 bars of soap available altogether. 12 of them are unscented, 3 allspice nutmeg, 18 bay rum, and 6 bergamot/chamomile. I have entered the amount I have of each scent in the quantity window in the option values manager but it does not show when the customer is shopping. The customer can order 13 unscented bars, but not 40. So the stock appears to be limited only by what I put in the product description, not the quantity I state in the options menu.
    Check stock is true, Subract stock is true, Allow checkout is false.
    What setting should I adjust to get the cart to show and enforce my inventory?
    thank you,
    Meg
    Default Re: attributes separate stock-need inventory help!
    Check other posts in the contributions forum for this module
    May 2007
    also, the only way I could get it to price things correctly was to make " product priced by attributes" a NO...
    the unscented bars have a base price, scented bars carry an increase that I enter with the attributes controller....doesn't that mean that the product IS priced by attributes? why then, if I check YES, does it only charge the extra, but not the base price when I select a scented bar...it charges me nothing for an unscented bar, despite the fact that I have the base price in the product description.
    thanks,
    Meg
    May 2007
    *there aren't any that I can find, only posts for the "stock by attribute" contribution
    This is where you need to configure prices and stock quantities....this should be in the admin product entry screen with stock-by-attributes options
    May 2007
    but that's my point...I don't have "stock by attributes", I have a different module that's not working the way it says it should. So am I making a mistake, or do I have to remove the "attributes separate stock" module and install another that will actually work?
    -m
    Well, you have a different module??? fill in the details:
    What module are you using?
    Who is the author?
    What version is it?
    What ver of ZenCart are you using?
    May 2007
    Leicester, England
    Have a Drink Re: attributes separate stock-need inventory help!
    I think that this is what you require, although I think there may be some issues about inventory/ stock control etc. The module is located in the 'Other Modules' section of the Downloads on the zen-cart.com web site.
    Stock by Attributes
    Last Updated by: kuroi Jan 06 2007 v1.3.7 4.4
    May 2007
    Thank you, blag,
    I've got someone working on it for me now, we're removing the module had and she'll install Kuroi's contribution instead...
    thanks!
    -meg
  1. v154 Need stock by attributes help
    By jmocallghan in forum Setting Up Categories, Products, Attributes
    Last Post: 8 Feb 2015, 11:11 PM
  2. v151 Inventory Stock by Attributes
    By Kevin205 in forum General Questions
    Last Post: 6 Jul 2013, 04:53 PM
  3. Have added attributes to each stock item - now need to add inventory??? HOW
    By teazerr in forum Setting Up Categories, Products, Attributes
    Last Post: 23 Apr 2011, 02:51 PM
  4. Attributes Separate Stock Addon
    By Destroyer in forum All Other Contributions/Addons
    Last Post: 9 Nov 2010, 09:30 PM
  5. Default attribute using Attributes Separate Stock
    By fightthefourwalls in forum Setting Up Categories, Products, Attributes
    Last Post: 17 Aug 2009, 08:12 AM
