crispyburgers
first of all, what a welcome alternative to that other e-commerce system!
i have installed zencart at
www.the-pred.co.uk/zencart .
i have changed the provided template to a template called "gloss black" The problem i have with it, is that all the products and boxes appear "over large" on the main page and in the categories UNLESS a product is searched for in the header search box, when everything appears OK.
The problem detracts from the site so much, i have currently removed all the side boxes whilst i try to find the solution (so far without success.)
The style sheet is attached to this post - i hope you can access it Any advice would be gratefully received!
I presume the problem is a stylesheet problem, but I am a newbie to all this php stuff, so i am not sure.
When I view the source of the page with the problem, you have an extra <title> tag above everything:
<title>www.the-pred.co.uk online shop</title><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en">
<head>
<title>X10 : Zen Cart!, www.the-pred.co.uk</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
Perhaps you added that to a file, as you wanted that to be your title? That needs to go.
I think that will fix your problem, your css is fine.
