Hello, I am having trouble trying to find out which line of code to edit to make my left side column spaced the same as the right side. Can someone tell me or show me the line of code I should edit.
Did you compare the padding settings in your stylesheet.css file for the two columns and change them to match?
HTH,
Lesli in SW Florida ~ writer, teacher, and dodging hurricanes!
You might also check in your Admin/Configuration/Layout Settings
for your Column-Left/Right Boxes and Column Left/Right width settings.
