Hi guys,
Glad to be here. I am new to php and this zen cart as well, so it is good to have such a cool place to consult and get your kindly help.
Please see this sample (http://www.tulipbling.com/). Basically, I have two categories, one is Products (such as Shop by Category), the other is Industries (such as Shop by Mateiral). Both of them has two level sub-categories. In a word, the default template has Categories Box in left column when I finished the installation, now I want to add another Box below Categories Box which has the exact function as Categories Box, how could I do that? Please tell the detail steps if possible. :)) Thank you very much for the help!!
. Fortunately, you mentioned a little bit about this second solution, but I am not very clear what to do for "using the "Documents" product type assigned to categories so that products in those categories are handled by the Documents sidebox instead of the Categories box.". Well, I did have a try by myself but it did not work out. And I have sample categories installed when I installed zen-cart, so right now there is a Documents category under the Categories/Products, if I click it, it will jump to its page where I can add new product, but there is no "new category" button for adding a sub-category under the Documents category.
I will take a look at it.
