Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
    Jul 2006
    Default Quotes have issues affecting my product images [NOTE: magic_quotes_sybase issue]
    I'm using the latest version.
    It seems that if the product name has a single quote in it, the image will not display. Is this normal? How can I fix this?
    Dec 2004
    New York, USA
    Default Re: Quotes have issues
    Try putting a escape backslash \ in front of each single quote. PHP is getting confused with the single quotes and so for your text they need to handled with some extra care.
    more info :: PHP Manual - Strings
    edit:
    FAQ :: reference
    Jul 2006
    Okay, I tried that and got this error:
    1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's Poem Und. Plexi Glass', products_description = '12" X 15" Simulated Walnut Pla' at line 1
    in:
    [update zen_products_description set products_name = '12" X 15" Sim. Wal. Plq. Chief\''s Poem Und. Plexi Glass', products_description = '12" X 15" Simulated Walnut Plaque, Chief''s Poem Under Plexi Glass With 5 Trumpet Hat Badge.', products_url = '' where products_id = '3739' and language_id = '1']
    I had changed 12" X 15" Sim. Wal. Plq. Chief's Poem Und. Plexi Glass to 12" X 15" Sim. Wal. Plq. Chief\'s Poem Und. Plexi Glass
    Dec 2004
    New York, USA
    Sorry, my initial reply pertained more toward language defines and such. How are you entering this product's data? Is it via the ZC Categories/Products admin, or are you trying to import data with an add-on or other non-Zen-Cart tool?
    afaik, ZC properly sanitizes the inputed data upon submission to avoid such issues. I've checked with a clean installation of ZC 1.3.7, and using single or double quotes randomly within the Product Name and/or Product Description does not demonstrate the issue you are experiencing.
    Jul 2006
    Here is the product that has the issue:
    http://aaau.com/cart/index.php?main_...oducts_id=3739
    I am entering it normally, via the admin section.
    If I simply delete the quote, the page is fixed and the image shows up.
    If you disable javascript in your browser, does it work properly ?
    What addons and customizations have been done to your shop?
    Jul 2006
    Yes, it works fine if Javascript is disabled.
    I should mention most other product images work fine.
    I believe the only changes have been changes to the template.
    Default Re: Quotes have issues affecting my product images
    Please post the contents of your /includes/templates/YOURTEMPLATE/templates/tpl_modules_main_product_image.php file.
    Jul 2006
     * Module Template
     * @package templateSystem
     * @version $Id: tpl_modules_main_product_image.php 3208 2006-03-19 16:48:57Z birdbrain $
    <?php require(DIR_WS_MODULES . zen_get_module_directory(FILENAME_MAIN_PRODUCT_IMAGE)); ?>
    <div id="productMainImage" class="centeredContent back">
    <script language="javascript" type="text/javascript"><!--
    document.write('<?php echo '<a href="javascript:popupWindow(\\\'' . zen_href_link(FILENAME_POPUP_IMAGE, 'pID=' . $_GET['products_id$
    //--></script>
    <noscript>
      echo '<a href="' . zen_href_link(FILENAME_POPUP_IMAGE, 'pID=' . $_GET['products_id']) . '" target="_blank">' . zen_image($product$
    </noscript>
    It appears that your file is corrupt.
    Please re-upload that file from your original Zen Cart zip.
    Be sure to replace the template_default one with the one from the zip, and if you have the same file in various template override folders, be sure to either replace them with the master or merge your customizations with the master before uploading and replacing the one in your overrides folders.
  1. v139h Price by Attribute issue affecting all products when one attribute is out of stock.
    By NCRS 1962 in forum All Other Contributions/Addons
    Last Post: 11 Dec 2012, 02:11 AM
  2. Issue with resizing window affecting layout
    By tabitha in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Nov 2009, 08:00 PM
  3. Replies: 1
    Last Post: 11 Jun 2007, 07:13 PM
  4. Credit Note issue page?
    By Stevis2002 in forum All Other Contributions/Addons
    Last Post: 27 May 2006, 09:43 PM
