At checkout I get the following : a 404 page not found, The requested URL /intackshop/zc_install/index.php was not found on this server.
The path the host supplied is
https://www1.securesiteserver.co.uk/username/.
The username supplied is 10 digits.
I've set the config files as below.
define('HTTP_SERVER', 'http://www.intackshop.co.uk');
define('HTTPS_SERVER', 'https://www1.securesiteserver.co.uk/username');
define('ENABLE_SSL', 'true');
define('DIR_WS_HTTPS_CATALOG', '//');
define('DIR_WS_PHPBB', '/');
define('DIR_FS_CATALOG', '/domains/i/n/intackshop.co.uk/public_html/');
define('DB_TYPE', 'mysql');
define('DB_PREFIX', '');
define('DB_SERVER', 'l'); // eg, localhost - should not be empty
define('DB_SERVER_USERNAME', '');
define('DB_SERVER_PASSWORD', '');
define('DB_DATABASE', '');
define('STORE_SESSIONS', 'db'); // leave empty '' for default handler or set to 'db'
define('DIR_FS_SQL_CACHE', '/domains/i/n/intackshop.co.uk/public_html/cache');
and
// Main webserver: eg, http://localhost - should not be empty for productive servers
// HTTP_CATALOG_SERVER is your Main webserver: eg, http://www.yourdomain.com
// HTTPS_CATALOG_SERVER is your Secure webserver: eg, https://www.yourdomain.com
define('HTTP_CATALOG_SERVER', 'http://www.intackshop.co.uk');
define('HTTPS_CATALOG_SERVER', 'https://www1.securesiteserver.co.uk/username');
define('DIR_WS_ADMIN', '/admin/');
define('DIR_WS_HTTPS_ADMIN', 'https:///admin/');
define('DIR_WS_HTTPS_CATALOG', 'https:///');
define('DIR_FS_ADMIN', '/domains/i/n/intackshop.co.uk/public_html/admin/');
define('DB_SERVER', 'localhost'); // eg, localhost - should not be empty
I'm using Zen Cart 1.3.0.1
Any help much appreciated
