Results 1 to 7 of 7
    Mar 2007
    Default Pricing by weight or volume for some products only
    I'm working on a store at https://www.coffeemamma.com.au/store/
    I'm a bit sub par with attributes, but I need to set a product up so that different weights of the same product are available.
    If you look at https://www.coffeemamma.com.au/store...&products_id=3
    it has the functionality I need, but not the user friendliness or intuition.
    How do I use attributes to have 250g = price A, 500g = price B and 1000g = price C? Especially when different products have different prices for the same weights?
    I'd also like to have syrups at 250ml = price X and 750ml = price Y, but I assume that the answer for the weights will also translate to the syrups
    I've put a text file at www.coffeemamma.com.au/weights.txt which may help you understand better...
    I also need to put the 'weights' options up under the body text. In other words I'd like to put either a drop box or the radio buttons which are currently under the 'Grind' up where the bullet points are with the weights
    Bruce
    ** EDITED *** Never ever post in a forum, email, newsletter etc. the zenid or zenAdminID or you will be doomed!!
    Mar 2007
    Default Re: Pricing by weight or volume for some products only
    Does anyone have any suggestions for me - even if it is just that I reword the question?
    TIA
    Bruce
    Did you try adding the price to the Attributes?
    Either you enter them as:
    products_price 2.50
    small + 0.00
    medium + 0.50
    large + 1.00
    Or as:
    products_price 0.00
    products_priced_by_attribute Yes
    small 2.50
    medium 3.00
    large 3.50
    Mar 2007
    Quote Originally Posted by brucecode View Post
    Hi Ajeh,
    What is the 'zenid' or 'zenadminID' ?
    I don't know what you have removed in order for me to identify what you mean?
    TIA,
    Bruce
    Mar 2007
    products_price 2.50
    small + 0.00
    medium + 0.50
    large + 1.00
    Or as:
    products_price 0.00
    small 2.50
    medium 3.00
    large 3.50
    Hi Ajeh,
    Something I have just thought of as I started to try to implement these suggestions:
    How do either of these suggestions effect the weight? In my example, small is 250gm, medium is 500gm and large is 1,000gm. This will obviously effect the price of shipping, but how do I program that in so that Zen Cart updates the price, weight and shipping accordingly?
    Bruce
    Mar 2007
    Hi All,
    Is there a shipping price by weight attribute or add-on that I can use for this?
    Bruce
    Zen Cart uses an unit of weight ...
    We call it lbs but this can be grams or what have you ...
    The problem is you need to translate it when trying to use mixed units of measure ...
    Simply changing the text from lb or lbs to grams is purely a text define issue ...
    Now you need your shipping module to manage that correctly ...
    Example: UPS expects weight in pounds ... USPS expects weight in Pounds and ounces ... Other shipping modules might expect the weight in grams ...
  1. Multiple Products / Volume Pricing
    By alamo in forum General Questions
    Last Post: 21 Dec 2009, 09:56 PM
  2. Weight vs volume for Aus Post
    By jenpen in forum Addon Shipping Modules
    Last Post: 7 Jul 2008, 09:11 AM
  3. Flat Rate for some products, ship by weight for other products
    By caspar in forum Built-in Shipping and Payment Modules
    Last Post: 28 Mar 2007, 01:12 AM
  4. per unite weight only for some items
    By bangsters in forum General Questions
    Last Post: 13 Dec 2006, 04:44 AM
  5. Can I make some products ship-only, some pickup-only, some both?
    By TheToe in forum Setting Up Categories, Products, Attributes
    Last Post: 7 Nov 2006, 12:33 AM
