Results 1 to 7 of 7
    Mar 2007
    Default Navigation at the top ! Pleaseeee Help ,
    Please help.
    How can we add a navigation toolbar at the top.
    You know a hom page and so on.
    Is this possible ?
    Mar 2007
    Default Re: Navigation at the top ! Pleaseeee Help ,
    PLEASE HELP ! ! !
    Mar 2007
    Please show me the way and Thank you.
    Feb 2007
    Leicester UK
    There's one already built in using the EZPages feature. Some tinkering with the stylesheet will make it look exactly the way you want it to.
    Mar 2007
    Quote Originally Posted by spbennett View Post
    Ok where do i find the style sheet ?
    Dec 2006
    Victoria, Australia
    A navigation bar will [FONT=Arial]automatically[/FONT] appear as you add your categories and your pages at the top under your header if you turn on the
    header box icons
    If you want to customize the look of the nav bar example : colour etc you do this in the stylesheet.
    The stylesheet is found here: Includes/templates/default_template/CSS/stylesheet.css
    You need to make your alterations and place a copy in your override folder:
    Includes/templates/CUSTOM/CSS/stylesheet.css
    Mar 2007
    Thanks for the help guys.
  1. v151 How do I increase the size of the top navigation bar
    By mespe in forum General Questions
    Last Post: 22 Mar 2015, 03:57 PM
  2. v151 TPL_product_info-display.php HELP PLEASEEEE
    By rbecq in forum Setting Up Categories, Products, Attributes
    Last Post: 16 Jun 2013, 09:38 AM
  3. changing the size of the top navigation bar
    By 4cat in forum Templates, Stylesheets, Page Layout
    Last Post: 31 Aug 2010, 03:10 PM
  4. remove navigation on the top
    By Mistica1507 in forum Basic Configuration
    Last Post: 20 Sep 2007, 06:25 PM
  5. Help with install pleaseeee
    By wickproducts in forum Installing on a Windows Server
    Last Post: 6 Jun 2006, 10:54 PM
