Results 1 to 3 of 3
    Jun 2007
    Default FLASH PRELOADER won't work
    hello. I am very new at this and I am having problems making a flash perloader work I have been about to make a flash file load however the when I put a perloader that will load the content flash file all the remains is a black box. If there is another thread that deals with this subject I am sorry I didn't see it. I have been searching for hours and I really need some help.
    I was wondering if anyone knows how to add flash to the header of Zen Cart. I can't seem to add a preloader that can load in the flash content.
    if you want to see what I mean you can check out the site
    www.stoppoints.com
    you can see the flash has a preloader when it loads on the index page but when you click on buy and zen cart is loaded I can't make the flash preloader work so I had to just load in the flash by itself thus there is a black space until the flash is loaded any help would be great
    thank you very much for taking the time to read this message any help would be great
    Default Re: FLASH PRELOADER won't work
    Can you make it work from a regular .html file on your site ... outside of the Zen Cart framework? If so, please post a link to that page.
    Once you have it working "there", then look at integrating it into the Zen Cart template.
    Jun 2007
    I want to thank you very much for your help. It seemed to be the path that I entered that told the perloader where to find the content. I am not sure why the preloader needed to have a path like this
    includes/templates/lovely/images/stoppointsflashmovieone.swf
    instead of just this
    but it seems to work none the less
    thank you very much for you reply
  1. Why won't Flash using XML file load images?
    By wasana in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Dec 2010, 07:13 PM
  2. Flash Header won't work? Please Help
    By craigpowell in forum Templates, Stylesheets, Page Layout
    Last Post: 16 Sep 2008, 01:00 PM
