    Dec 2004
    help question Problem with Securing my site
    My website is not public yet because I cannot complete security my site. Renameing the admin folder and editing the two configure.php files is the issue with the problem.
    I have followed what I believe is the exact instruction and fail to get it right. I feel as though there is something I am missing.
    I make the changes as suggested then try to enter the admin area and I do get the log in page but my log in fails to "page not found". I have done this several times now and I am almost ready to scream. Any suggestions to offer?
    The instruction:
    A- Open your admin/includes/configure.php, using a simple text editor like notepad.
    Change all instances of /admin/ to your chosen new admin folder-name.
    Change this section:
    define('DIR_WS_ADMIN', '/admin/');
    define('DIR_WS_HTTPS_ADMIN', '/admin/');
    And this section:
    define('DIR_FS_ADMIN', '/home/mystore.com/www/public/admin/');
    define('DIR_FS_CATALOG', '/home/mystore.com/www/public/');
    B- Find your Zen Cart /admin/ directory, using your FTP software or your webhost File Manager.
    Rename the directory to match the settings you just made in your admin/includes/configure.php.
    My changes look like this:
    define('DIR_WS_ADMIN', '/newname/');
    define('DIR_WS_HTTPS_ADMIN', '/myname/');
    And this section:
    define('DIR_FS_ADMIN', '/home/mywebsitename.com/www/public/newname/');
    define('DIR_FS_CATALOG', '/home/mywebsitename.com/www/public/');
    Where I entered newname is where I put my new directory name.
    Where I entered mywebsitename.com is where my actual website name is.
    What am I doing wrong?
    Default Re: Problem with Securing my site
    Quote Originally Posted by peppyone View Post
    And this section:
    1. Are you sure you wanted "myname" here? Shouldn't it also be "newname" ?
    2. In these lines, the ONLY part you should have changed was "/admin/" to "/newname/":
    If it already had "mywebsitename.com", that's fine, but you should NOT have touched anything on those lines other than changing /admin/ to /newname/
    Dec 2004
    help question Re: Problem with Securing my site
    Yes that was a mistake in my post. I did actually type in my newname.
    All should be well, right? But it isn't.
    2. In these lines, the ONLY part you should have changed was "/admin/" to "/newname/":If it already had "mywebsitename.com", that's fine, but you should NOT have touched anything on those lines other than changing /admin/ to /newname/
    Jun 2003
    Have you FTPed or accessed the Zen Cart files and directories and renamed the admin directory to match your NEW_NAME? (note it is case sensitive and should not have any spaces in the name)
    Dec 2004
    Hi Kim,
    Yes I did that. I actually use either Cute FTP or Dreamweaver. Not once but a few times now. I have used a simple name, all lower case. I am totally stumped.
    I thought maybe more than the examples may have been required. I have been careful about the spacing and I am not a complete novice and I am very careful with detail. I guess just not careful enough. Lost in the world of Zen Cart.
    Toni
    Dec 2004
    for Kim and DrByte,
    I appreciate your replies. I did resolve the problem. I dug around to some earlier posts and found someone with the same problem I had.
    I think the problem was I was using dreamweaver to edit my configure.php files. This time I repeated the process using notepad and everything went as smooth as silk.
    I was going crazy. So now I will proceed to secure my site and not use dreamweaver.
    Toni
  1. Help with securing site (SSL)
    By JulieNicole23 in forum General Questions
    Last Post: 27 Mar 2008, 04:54 AM
  2. securing site wont work
    By Dale Dugas in forum Templates, Stylesheets, Page Layout
    Last Post: 27 Jan 2008, 11:46 PM
  3. Securing /includes/admin by renaming; problem with links
    By caffiendo in forum Templates, Stylesheets, Page Layout
    Last Post: 1 Feb 2007, 10:29 PM
  4. Securing my site...
    By Alex Clarke in forum General Questions
    Last Post: 7 Oct 2006, 02:30 PM
