Forums / Templates, Stylesheets, Page Layout / Products URL not showing
Locked
Results 1 to 8 of 8
17 Aug 2007, 11:32
#1
kpax avatar
kpax
New Zenner
Apr 2007
18
Plugin Contributions:
Hi there,
I've got some problems implementing the link (Products URL) to another page with more information on my tpl_product_info_display.php page.
Basically, the code is all there and looks good and in Admin under 'Product Types' -> 'Product - General' I've made sure that the 'Show Product URL' option is enabled.
In the DB I can see my inserted URL just fine and the #productInfoLink style shows in the correct spot on the product info page, unfortunately just without any content though..
Is there any other file I would have to amend to make that Products URL link show up?
17 Aug 2007, 13:00
#2
kpax avatar
kpax
New Zenner
Apr 2007
18
Re: Products URL not showing
I've just found the answer myself.
Under includes/languages/english/my_template/product_info.php I had, for whatever reason.., removed the text for TEXT_MORE_INFORMATION.
Put it back in and everything's looking fine now.
thanks to all for looking into this anyway.
kpax
23 Aug 2007, 14:03
#3
cozmic avatar
cozmic
New Zenner
Apr 2006
24
I have the same problem but my TEXT_MORE_INFORMATION have not been changed and still the link which says: "For more information, please visit this product's web page" doesn't show up.
I've entered a valid url in the products page also. Is there somewhere else where I configure to display this info?
Please help, pretty frustrated here :)
Running 1.3.7
23 Aug 2007, 14:16
#4
ajeh avatar
ajeh
Oba-san
62,757
Check in the Catalog ... Product Types ... click on EDIT LAYOUT and ensure that the URL is turned on for display ...
23 Aug 2007, 15:15
#5
cozmic avatar
cozmic
New Zenner
Apr 2006
24
Thanks for the reply but unfortunately this was already set to true.
Any more ides Ajeh?
Kind regards
23 Aug 2007, 15:19
#6
ajeh avatar
ajeh
Oba-san
62,757
Check your template and see if it has removed the code for displaying the URL ...
[PHP]<!--bof Product URL -->
if (zen_not_null($products_url)) {
if ($flag_show_product_info_url == 1) {
<p id="productInfoLink" class="productGeneral centeredContent"><?php echo sprintf(TEXT_MORE_INFORMATION, zen_href_link(FILENAME_REDIRECT, 'action=url&goto=' . urlencode($products_url), 'NONSSL', true, false)); ?></p>
} // $flag_show_product_info_url
<!--eof Product URL -->
[/PHP]
24 Aug 2007, 08:37
#7
cozmic avatar
cozmic
New Zenner
Apr 2006
24
My custom template doesn't override tpl_product_info_display.php in templates_default. I'll keep searching if i can find other modifications...
24 Aug 2007, 14:41
#8
cozmic avatar
cozmic
New Zenner
Apr 2006
24
I've found the error at last. It was another product_info.php under my template dir that had the TEXT_MORE_INFORMATION removed.
Thanks for help, now I can go home :)
