Results 1 to 7 of 7
    Aug 2007
    help question Products Also Purchased
    I am adding products to my site and all of the sudden, now when I click on one of my products, this comes up at the bottom of the page:
    Warning: main(includes/templates/template_default/templates/tpl_modules_also_purchased_products.php): failed to open stream: No such file or directory in /home/content/e/r/i/ericasf/html/store/includes/templates/template_default/templates/tpl_product_info_display.php on line 233
    Fatal error: main(): Failed opening required 'includes/templates/template_default/templates/tpl_modules_also_purchased_products.php' (include_path='.:/usr/local/lib/php') in /home/content/e/r/i/ericasf/html/store/includes/templates/template_default/templates/tpl_product_info_display.php on line 233
    Any idea why?
    Default Re: Products Also Purchased
    Quote Originally Posted by bellagraysboutique View Post
    It appears that you're missing a file ...
    Aug 2007
    So if I just upload that file, will that fix it?
    Oct 2006
    That question is...impossible to answer, really. Why don't you just try uploading it, see if it fixes the problem. If not then post any other errors here.
    I no longer provide installation support on forum for all my modules. However, if there are real bugs with the modules please feel free to contact me
    Aug 2007
    So I went into my FTP files and the issue was that when the files were uploaded, their file names were cut off, so say the file needed was abc.php, it was only showing abc.ph so it wasn't recognizing the file. Strange..........
    Oct 2006
    Then it's either the your ftp client or your host causing the problem. What happens if you rename those files?
    Aug 2007
    It fixed it when I renamed it. So it's a restriction on the number of characters in a file name by my host?
  1. Also Purchased products
    By sjemms in forum Basic Configuration
    Last Post: 18 Dec 2010, 02:56 AM
  2. Also Purchased Products
    By krdzal in forum General Questions
    Last Post: 3 Jan 2010, 01:06 AM
  3. Also purchased products
    By pivey in forum General Questions
    Last Post: 25 Sep 2006, 03:02 AM
