Results 1 to 3 of 3
    Jul 2007
    Default Another SSL problem...
    Sorry if you've seen this thread before. I posted in a completely wrong category.
    The cart is here: http://www.angeltreasures.com
    It is hosted on GoDaddy with an Turbo SSL. The SSL is installed. I've changed both the includes/configure.php file and the admin/includes/configure.php so that ENABLE_SSL is 'true'. I can get it to work if I manually type https instead of http but it won't do it automatically (like if I click on the normal login link).
    As a side note, I've also noticed that my css styling disappears on the https pages... and I've also got those weird address duplication errors with https.
    Any help would be awesome!
    CONFIGURE.PHP below
      define('HTTP_SERVER', 'http://www.angeltreasures.com');
      define('HTTPS_SERVER', 'https://www.angeltreasures.com');
      define('ENABLE_SSL', 'true');
      define('DIR_WS_PHPBB', '/');
      define('DIR_FS_CATALOG', '/home/content/l/s/a/lsalzer/html/');
      define('DB_TYPE', 'mysql');
    etc
    Mar 2004
    Default Re: Another SSL problem...
    can you 1 try switching to the classic template and see if this continues,
    if not then can you post the code from
    includes/templates/YOUR TEMPLATE/common/html_header.php
    Jul 2007
    OMG, freaking GoDaddy. I'm sorry, it looks like it was GoDaddy messing with the server that was causing the problem. I reuploaded the configure files after they finished and it now works properly. Thanks for your time! If anyone else has a problem, don't forget to check on what your host is doing to on your account.
  1. Another SSL thread...
    By Crooked_Halo in forum Basic Configuration
    Last Post: 10 Aug 2008, 03:25 PM
  2. another SSL problem
    By shobuz99 in forum Basic Configuration
    Last Post: 29 Jul 2008, 04:28 PM
  3. Another SSL issue
    By Mineralicious in forum General Questions
    Last Post: 4 Jun 2008, 06:12 AM
