I have installed Zen Cart on my own Apache2 webserver. I have bought and installed my SSL certificates, and when I add an HTTPS to my website name, or use the admin panel, I do show a lock in my browser.
However, thats the only time I see it. The website is not going into secure mode when I go to checkout. I am using the AUTHORIZE.NET (AIM) and credit card transactions are going through and being approved and denied. Can somebody give me a hand?
This is a relevant file on my Apache server, have I done something wrong? The SSL admin panel works just fine. Is it my apache config?
Please help, thankyou!
NameVirtualHost *:80
NameVirtualHost *:443
<VirtualHost *:80>
ServerAdmin webmaster@localhost
DocumentRoot /var/www
<Directory />
Options FollowSymLinks
AllowOverride None
</Directory>
<Directory /var/www>
Options Indexes FollowSymLinks MultiViews
AllowOverride None
Order allow,deny
allow from all
# This directive allows us to have apache2's default start page
# in /apache2-default/, but still have / go to the right place
RedirectMatch ^/$ /catalog/
</Directory>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options ExecCGI -MultiViews +SymLinksIfOwnerMatch
Order allow,deny
Allow from all
</Directory>
ErrorLog /var/log/apache2/error.log
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
CustomLog /var/log/apache2/access.log combined
ServerSignature On
Alias /doc/ "/usr/share/doc/"
<Directory "/usr/share/doc/">
Options Indexes MultiViews FollowSymLinks
AllowOverride None
Order deny,allow
Deny from all
Allow from 127.0.0.0/255.0.0.0 ::1/128
</Directory>
</VirtualHost>
<VirtualHost *:443>
SSLEngine on
SSLCertificateKeyFile /etc/apache2/www.mustanglighting.com.key
SSLCertificateFile /etc/apache2/www.mustanglighting.com.crt
<Directory />
AllowOverride None
</Directory>
AllowOverride None
Order allow,deny
allow from all
</Directory>
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# alert, emerg.
LogLevel warn
ServerSignature On
AllowOverride None
Order deny,allow
Deny from all
</Directory>
</VirtualHost>
Here is some of /includes/configure.php. Do I need to show more?
define('HTTP_SERVER', 'http://www.mustanglighting.com');
define('HTTPS_SERVER', 'https://www.mustanglighting.com');
define('ENABLE_SSL', 'TRUE');
define('DIR_WS_CATALOG', '/catalog/');
define('DIR_WS_HTTPS_CATALOG', '/catalog/');
And here is a bit of /admin/includes/configure.php
define('HTTP_CATALOG_SERVER', 'http://www.mustanglighting.com');
define('HTTPS_CATALOG_SERVER', 'https://www.mustanglighting.com');
