When i upgraded to didnt choose to have SSL's on, now nothing secure. So how do i turn them on. In the config file it states the https address but is there a setting in admin or something. No forms are secure or checkout or admin
cheers
paul
cheers
paul
You need to first buy an SSL certificate; then you can enable it in your cart. Look around - there are lots of companies selling them, and prices vary tremendously for the same actual security.
I have a secure area for my website, but i do not know how to make pages secure with it. I have put the secure address in the configure.php file but what do i need to do.
paul
is it in admin-include-configure.php
I changed both files to secure 'true'
and the one in admin has:
which are both now true
Yet site still not secure, login area does not have secure adrress neither does checkout, any ideas?
paul
Who is your host? Do they use a Plesk control panel?
yes that is correct..is it in admin-include-configure.php
Correct, but you have only done half the alterations..define('ENABLE_SSL_CATALOG', 'true');
In BOTH configure files, you also have to alter
defines for https server
i.e.
Code:define('HTTP_SERVER', 'http://yourzencart.com'); define('HTTPS_SERVER', 'https://yourzencart.com'); // Use secure webserver for checkout procedure? define('ENABLE_SSL', 'true');
