This is the URL
http://www.nrsportingimages.com.au/i...dex&cPath=9_43
How do I make the Images come first and the code after it.
ALSO
How can I make the attributes to the right of the page.
Nat
This is the URL
ALSO
Nat
OK I worked out the column order issue (well actually I found it elsewhere in the forum....Thanks Ajeh).
config>product listing>display product model.
For those of you only at my level, it doesnt actually tell you on the page but 0 is OFF 1 is for ON and then any other value after that is the Sort order of the displayed fields.
