    Jun 2007
    Milton Keynes UK
    Default additional images cause layout problems in IE7
    Has anyone else had this problem that I have?
    When I have additional images in a product page, the center column of the page spills over to the right under the right box column IN IE7 ONLY not FF
    Please let me know if you have a solution.
    Franco
    Oct 2004
    Southport, UK
    Default Re: additional images cause layout problems in IE7
    The easy fix is to find the IE specific stylesheets "mod" in the downloads and set up an IE7 specific stylesheet and make the necessary adjustments.
    Development Manager @ JSWeb Ltd - suppliers of Applepay/Googlepay for Zencart
    20 years with Zencart !
    Jun 2007
    Milton Keynes UK
    Quote Originally Posted by Ryk View Post
    Hi Rick
    As you know we did fix this problem but the way we fixed it is not stable. I have had a look at the style sheet override but my problem is the style sheet override code for IE7.
    Thanks anyway
    Franco
    Jun 2007
    Milton Keynes UK
    Rick, in any case the IE7 problem occurs only when you have additional images in the product page and apparently is connected to the tpl_columnar_display.php and the presence of the center column header box bar. (if you eliminate the bar code the problem is not there)
  1. Additional Images Layout
    By caesartrading in forum Templates, Stylesheets, Page Layout
    Last Post: 7 Jun 2011, 02:25 AM
  2. Layout of Additional of Additional Product Images - Possible Bug?
    By RatMonkey in forum Templates, Stylesheets, Page Layout
    Last Post: 25 Mar 2011, 02:21 PM
  3. Large Attribute Images - do they cause any problems
    By demiurgia in forum Setting Up Categories, Products, Attributes
    Last Post: 22 Jul 2010, 03:27 AM
  4. additional images incorrect display in IE7
    By gsdcypher in forum Templates, Stylesheets, Page Layout
    Last Post: 14 Mar 2009, 06:28 PM
  5. IE7 & Firefox layout problems
    By AngelusUK in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Sep 2006, 04:46 PM
