I need to figure out how to make the side of the menu section just a little bigger than the words.
If you go to our website www.AD-DiscountPerformance.com and look at the menu and see the words like the ATV and Boats and UTV could loose some padding on the sides of them and it would make some room for the other ones..
I am also trying to figure out how to remove the one that says Gift Certificates.
