Results 1 to 3 of 3
    Jan 2008
    Default How do you add a template - side panel problem??
    Hi all
    I've just successfully installed my first Zen cart to play with . I then downloaded a template from (sorry, site offline)/ called Silverfish.
    When I unzipped it, there was an 'includes' folder. This had a 'templates' folder and a 'modules' folder inside. Each of these had a 'silverfish' folder inside it.
    I transfered the silverfish folder that was in the templates one to the templates folder in my site, and the silverfish folder in the modules folder to the modules folder in my site.
    I then selected the silverfish option from the admin control panel. It looks fine except the side panels don't have anything in them!
    Where have I gone wrong, please? Is there something else I need to check?
    Newbie (I've ordered the book!)
    http://showexamples.co.uk/zenny/
    Jun 2003
    Default Re: How do you add a template - side panel problem??
    Go to Admin> Tools> Layout Boxes Controller, scroll to the bottom and click the reset button
    Jan 2008
    Many thanks! I just worked it out as you posted!!
    Now, where on earth do I begin ....
  1. TuSet position Banner2 + How to add bottons to the higher panel?
    By Heenessy in forum Templates, Stylesheets, Page Layout
    Last Post: 2 Mar 2011, 05:31 PM
  2. how do you edit links in the side boxes ?
    By stardusk in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Jul 2009, 07:19 AM
  3. How to Add SSL Seal to Side Bar Under Side Boxes
    By jacdesigner in forum Templates, Stylesheets, Page Layout
    Last Post: 20 Mar 2009, 08:54 AM
  4. How do you add text to last Thank You page after purchase complete?
    By catangirl in forum Templates, Stylesheets, Page Layout
    Last Post: 24 Sep 2007, 10:25 PM
  5. How do you add space (padding) to text in side boxes
    By cnsystems in forum Templates, Stylesheets, Page Layout
    Last Post: 13 Aug 2006, 06:12 PM
