    May 2005
    Leicester, UK
    Default SQL error when using Protx module and zones
    In Admin when I select an order to view, I get the following error msg:
    1054 Unknown column 'U' in 'where clause'
    in:
    [ SELECT zone_id FROM zen_zones_to_geo_zones WHERE geo_zone_id = 2 AND zone_country_id = U ORDER BY zone_id ]
    Running zc.1.3.7., using zone_rates for shipping, protx_direct for payment, Sales Report & User Tracking, UK template.
    I suspect that the error may have something to do with zone definitions or tax classes. I un-installed a number of things like flat rate shipping before it want awol.
    However, I've compared this shop's database with another UK shop database, & there doesn't seem to be any real difference btn the 2.
    Any suggestions? Thanks!
    Eddie
    May 2005
    Leicester, UK
    Default Re: Can't view Admin Order => sql error (RESOLVED)
    Hi all,
    I've just resolved this 'issue' - stupid user (me) I'm afraid. I'd set the Payment Zone on the Protx_direct payment module to UK. Resetting it to 'none' did the trick - now I can edit orders, etc. Yipee!
    Cheers,
    Eddie
    Thanks for the update ... always a help to others ...
    May 2005
    Leicester, UK
    Default Re: SQL error when using Protx module and zones
    Hi Ajeh,
    I am still left wondering why this change should lead to a sql error?
    Can you reality check my understanding of this module? Am I correct in thinking that when you set a payment zone in a payment_module, you are essentially saying accept this payment type in this zone only?
    If so, I would expect that changing the payment zone as I did (from 'none' to my own 'UK') would lead to an error along the lines of, 'Sorry, but no orders found for this payment zone ....' rather than a SQL error.
    Does this error msg imply that the error handling needs attention?
    Eddie
    Quote Originally Posted by ECM View Post
    your assumptions are correct.
    Must be a bug in the module's code where zones are handled.
    Sep 2007
    Hi all,
    Cheers,
    Eddie
    Thank you for putting this on the forum,
    It is the unexpected solution.
    I have had a disaster. I moved server as it was slow, having just added superorders but not uploading the sql. That took weeks to sort out as my protx account suddenly would not return successful orders and then this latest error on the orders meaning I could not change the details to processing etc.
    There are so many interrelated things to look at.
    Hopefully I can now go live.
    Will
    www.designerspecsbypost.co.uk
  1. v139h DB/SQL Error when using SQL Patch for Add Pages More Info Sidebox addon
    By maperr55 in forum All Other Contributions/Addons
    Last Post: 5 Mar 2012, 09:32 PM
  2. Error when using the SQL patch section.
    By arcanesanctuary in forum General Questions
    Last Post: 10 Oct 2009, 03:45 AM
  3. Enabled zones for protx module, now admin fails to show order
    By neekfenwick in forum Addon Payment Modules
    Last Post: 4 Sep 2009, 12:01 PM
  4. Replies: 7
    Last Post: 23 Jul 2009, 06:53 AM
  5. Protx Installation sql error
    By Manor in forum Addon Payment Modules
    Last Post: 21 May 2009, 09:42 AM
