I would like to see the code you used to change the comments from text to drop down. If you could email or post that would be appreciated.
KMF
KMF,
I don't have the code anymore (couldn't find it) but if you read my post above it's all laid out. Basically just change the text area to a dropdown. So that would be:
<textarea name="comments"></textarea>
... change to ...
<select name="comments">
<option value="choice1">Choice 1</option>
<option value="choice2">Choice 2</option>
<option value="choice3">Choice 3</option>
</select>
And what that will do is just change the type of input field but the name is the same so it doesn't change anything about the way Zen processes it.
The only other step was validation that something was selected, so as I stated in my last post in this thread "I edited the file /includes/classes/payment.php and found the section of javascript that validates and added my validation code to it".
Hope that helps!
