Firstly, I am supposed to have this cart migrated this weekend, I think I can have the front end working but the admin sections not right.
I set the zencart up on Godaddy without a problem at all (and have set up several others without major issues)
This site is running fine on Godaddy. I am now moving it to net registry and I have had many hurles today which I have overcome but I am currently doing a fresh install for the 3rd time today.
I cannot login to the admin section. I know the username and password are right. I have tried setting up the temp username and Password as another post saidusing an sql query, the sql query said it went through fine but the user -Admin - pass-admin details did not work.
I am currently uploading zencart again, I will install it using a new database I will set up as well.
I will then preserve the 2 new configure.php files...upload the old files from Godaddy and then reinsert the preserved configure.php files
I will then drop the tables and import the database from the one I had set up on godaddy. I will use the same admin username at netregistry as I used at godaddy, so that should not be an issue.
This is exactly what I have done the last 2 times and wil do again.
I cant see that I have done anything wrong.
Can anyone else pull me up on anything that might be causing me not to be able to login to admin.
