Results 1 to 9 of 9
    Apr 2007
    Washington
    Default Featured Products in Top Level Catagory
    Hey, all. I've spent a while searching for this, but no luck.
    Pretty simple question... Forgive my verbage if I'm speak this incorrectly... I'm trying to get my featured listings to show up in a top level catagory. In other words, I've created a catagory and placed products in it. When that catagory is selected, I'd like the featured products to show up on the bottom of the page.
    A side note... If I have a sub-catagory, it's working perfectly (and on the main page). Just want it to work even if I don't have a sub-catagory.
    Thanks for the help!
    Cris C.
    Default Re: Featured Products in Top Level Catagory
    Post a link to the page in question
    Apr 2007
    Washington
    Thanks kobra,
    Here's one not working:
    http://ministryflix.com/index.php?ma...=index&cPath=5
    Here's one working (which is a subcatagory):
    http://ministryflix.com/index.php?ma...ndex&cPath=8_9
    Any help is appreciated!
    Cris
    What is your admin > config > index listing > Show Featured Products - below Product Listing > setting?
    Apr 2007
    Washington
    It's set at "2".
    Apr 2007
    Washington
    Just wanted to catch back up to see if you or anybody else had thoughts about why this is happening. Thanks.
    Cris
    This is an admin setting that you need to get right. As Kobra mentioned,
    configuration > index listing > Show Featured Products - below Product Listing controls this on the product listing page, and it should be set to 1,2,3 or 4 to display it there. If it is set to 0 it will not display.
    A setting of 2 should work... do you have any other centerboxes (new, all) with the same setting for the product listing page (they should be in sequence, not all set to 2 or something)?
    The pages where it is working are controlled by the
    Show Featured Products on Main Page - Category with SubCategories
    setting.
    Nov 2007
    My home page has the featured products in the centerbox. I've added a link to featured products in the sidebar in the categories listing (it shows up last which is fine). I did this by selecting under Layout settings, Categories Box - show featured products. However this display of featured products is different than my homepage featured products and each featured product (there are only 2) are set up differently.
    Home page (I like this display)
    http://sensiblysweetnj.com/index.php?main_page=index
    Featured Products - link from Featured Products in side bar
    http://sensiblysweetnj.com/index.php...tured_products
    Any ideas??? This is a template monster template which I now understand has many problems. I'm just trying to work around it.
    This is not exactly related to TM problems - the home page display is the featured products centerbox, while the link goes to the featured products listing page. They are different displays using different information and coding.
    It would be hard to tell you how to change yours, though, since TM has recoded them both for their design and standard solutions may not work.
  1. Replies: 0
    Last Post: 16 May 2011, 07:42 PM
  2. Products In Top Level Category Error
    By jill8026 in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Nov 2009, 04:22 PM
  3. Replies: 3
    Last Post: 26 Mar 2009, 07:12 AM
  4. Products in top level category
    By mmcs in forum All Other Contributions/Addons
    Last Post: 20 Mar 2009, 02:11 PM
  5. View all products in top level category?
    By doodlebee in forum Templates, Stylesheets, Page Layout
    Last Post: 15 Nov 2006, 11:53 PM
