I am installing Zen Cart on a development server, for testing purposes. There is no SSL certificate for the development server. How do I bypass the SSL-related warnings in the "System Inspection" part of the installation process so that I can press the "install" button and proceed to the next step? As of right now, I'm only getting CURL - SSL compatibilitiy errors, but when I press the "install" button, it takes me to the "Database Setup" page, which is BLANK except for the following intro text at the top: "Next we need to know some information on your database settings. Please carefully enter each setting in the appropriate box and press Save Database Settings to continue." There is NO form on the page for me to input my database settings. Also, CURL "is" enabled on my server.
OK, I tried to install the software again (run the installer again), and this time I get no significant errors. I've attached a screen snapshot to this post.
Nevertheless, I'm encountering the same problem as before. The subsequent "Database Setup" page is BLANK and there is NO form to input my DB settings.
What is going on here?
Please Help. Thank you.
