[FONT=Arial]Hi,[/FONT]
[FONT=Arial]I am installing Zencart on to my server and need to input the path for my PHPBB forum. Does this mean the physical path or the virtual path?[/FONT]
[FONT=Arial]For example my physical path for Zencart is: e:\domains\e\enchantedrealms.co.uk\user\htdocs[/FONT]
[FONT=Arial]And my Virtual path is www.enchantedrealms.co.uk/htdocs/store/[/FONT]
[FONT=Arial]On the server the forum configure file is located in www.enchantedrealms.co.uk/htdocs/phpBB3/[/FONT]
[FONT=Arial]And on my computer the forum is located within the Zencart files, in the store file, but I not sure what this would be.[/FONT]
[FONT=Arial]Also, while I am here, granted I haven’t set up Zencart fully yet, the database is running and up to date but I am half way through the installation on the server. However now when you go to www.enchantedrealms.co.uk it comes up with the following error:[/FONT]
[FONT=Arial]“Notice: Undefined variable: PHP_SELF in e:\domains\e\enchantedrealms.co.uk\user\htdocs\xampp\lang\en.php on line 252”[/FONT]
[FONT=Arial]what does this mean?[/FONT]
[FONT=Arial]Any help would be much appreciated. [/FONT]
[FONT=Arial]Thanks.[/FONT]
[FONT=Arial]Leanne.[/FONT]
