I ma importing my mySQL info from a .csv file and it goes through fine but when I go to my cart and test it out it does not show the new info. Do I need to do a reset or update of sorts?
When you import the products from a CSV into MySQL, which tables are you updating? There should be a record for the PRODUCTS table, which is the initial data. You then need to have some data imported into the PRODUCTS_DESCRIPTION table, which is where the name and description fields live. Finally, you need to tie the products to a category, which is done with a record in the PRODUCTS_TO_CATEGORIES table. Only when data is in all three of these tables, will your products show up.
Can you confirm that all these tables have records in them?
Absolute
