    Jan 2008
    Default Problem with Function Scope. $db->Execute works inline, but not in a function?!
    Hey guys,
    I've written a function called add_category. It works off the code from categories from php. I'm having a devil of a time with scope though. When I run the code inline, it runs fine. However, when I throw function add_category( ) { } around the code, it throws:
    Fatal error: Call to a member function Execute() on a non-object in /Applications/MAMP/htdocs/shop/admin/cat.php on line 105
    I know this is a weird global scope issue or something. At the top of my file I have...
    require_once('includes/application_top.php');
    global $db;
    Anyhow, What is the secret here? How do I work around this quirk. I'll be gosh durned and dipped in cherries before I use a goto.
    Josh
    Apr 2007
    Herts. UK
    Default Re: Problem with Function Scope. $db->Execute works inline, but not in a function?!
    Quote Originally Posted by enigmabomb View Post
    global $db;
    The global $db; needs to be inside the function instead of outside of it so that you have something like...
    function foobar()
        global
    $db;
    $res $db->Execute("select blah blah");
    // blah blah
    Regards,
    Christian.
    Jan 2008
    Christian,
    You continue to be an awesome source of knowledge. THANK YOU!
    Josh
    May 2008
    South Australia
    thankyou 2 :)
  1. v1.2.x Fatal error: Call to a member function Execute() on a non-object
    By musikmachine in forum General Questions
    Last Post: 15 Feb 2012, 12:21 AM
  2. Replies: 2
    Last Post: 5 Jul 2008, 04:27 PM
  3. Call to a member function Execute() on a non-object- ZC v1.2.6
    By warpdesign in forum Installing on a Linux/Unix Server
    Last Post: 17 Jun 2008, 03:07 PM
  4. Fatal error: Call to a member function Execute() on a non-object
    By OLDTango in forum Installing on a Linux/Unix Server
    Last Post: 28 Jul 2007, 03:43 PM
  5. Fatal error: Call to a member function Execute()...
    By shooter.ca in forum General Questions
    Last Post: 3 Dec 2006, 02:51 PM
