Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Sep 2006
    Default Re: Column / Grid Layout Problem
    I have made a newbie mistake, I didn't backup my db before running the sql that came with the version i had downloaded, now i see i ran the wrong one! I'm getting a syntax error on the SQL I'm running which came with the release:
    in('PRODUCT_LISTING_LAYOUT_STYLE','PRODUCT_LISTING_COLUMNS_PER_ROW');
    INSERT INTO configuration (configuration_title, configuration_key, configuration_value,
    configuration_description, configuration_group_id, sort_order,
    last_modified, date_added, use_function, set_function)
    VALUES ('Product Listing - Layout Style', 'PRODUCT_LISTING_LAYOUT_STYLE', 'rows',
    'Select the layout style:<br />Each product can be listed in its own row (rows option)
    or products can be listed in multiple columns per row (columns option)', '8', '40', NULL,
    now(), NULL, 'zen_cfg_select_option(array("rows", "columns"),');
    VALUES ('Product Listing - Columns Per Row', 'PRODUCT_LISTING_COLUMNS_PER_ROW', '3',
    'Select the number of columns of products to show in each row in the product listing.
    The default setting is 3.', '8', '41', NULL, now(), NULL, NULL);
    Now when I go to my products I get a blank page
    [FONT="Georgia"]Samuel Turnmire[/FONT]
    [FONT="Century Gothic"]co-Founder[/FONT]
    [FONT="Book Antiqua"]geekFoundry[/FONT]
    Sep 2006
    This is the error I get:
    1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'in('PRODUCT_LISTING_LAYOUT_STYLE','PRODUCT_LISTING_COLUMNS_PER_ROW')' at line 1
    in:
    [in('PRODUCT_LISTING_LAYOUT_STYLE','PRODUCT_LISTING_COLUMNS_PER_ROW');]
    Dec 2008
    I am also getting an error when I come to this step in the directions:
    Set the following settings:
    A. Product Listing - Layout Style
    Set the type of layout you want to use. By default, the current Zen Cart layout will be used.
    It is called "rows". If you want to use the column and row layout, choose "columns".
    The error is as follows:
    I 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '-0, 0' at line 7
    in:
    [select p.products_image, pd.products_name, p.products_quantity, p.products_id, p.products_type, p.master_categories_id, p.manufacturers_id, p.products_price, p.products_tax_class_id, pd.products_description, IF(s.status = 1, s.specials_new_products_price, NULL) as specials_new_products_price, IF(s.status =1, s.specials_new_products_price, p.products_price) as final_price, p.products_sort_order, p.product_is_call, p.product_is_always_free_shipping, p.products_qty_box_status from zen_products_description pd, zen_products p left join zen_manufacturers m on p.manufacturers_id = m.manufacturers_id, zen_products_to_categories p2c left join zen_specials s on p2c.products_id = s.products_id where p.products_status = 1 and p.products_id = p2c.products_id and pd.products_id = p2c.products_id and pd.language_id = '1' and p2c.categories_id = '1' order by p.products_sort_order, pd.products_name limit -0, 0]
    '-0, 0'
    It soulds like you have some admin setting at 0 in Configuration > Maximum Values. This can trigger an obscure bug, which has been discussed recently. Known Bugs (and fixes) with v1.3.8, post 34.
    Dec 2008
    '-0, 0'
    Thanks, that lead me to my solution:
    Configuration > Maximum Values > Products Listing- Number Per Page was conflicting.
    Explained:
    The default Configuration > Product Listing - Columns Per Row is 3, but I had changed it to 4.
    The default for Configuration > Maximum Values > Products Listing- Number Per Page is also 3. When changed to 4 the error disappeared.
    Thank you. I'll post in the Know Bugs thread as well.
    Jun 2009
    Hi, This is a new Install of 1.3.8 with Column Layout / Grid Layout
    I only installed a few items in my store, but they are only being displayed in 1 column. I have the settings to display in the standard 3 columns, but I must have missed something.
    any guesses?
    mtcoffinz.com/shop
    Jun 2009
    Well, if anyone else had this type of issue, check to make sure that you changed ALL of the "Your_Template" folders to your custom template name.
    That fixed it for me because I apparently missed one!
  8. #18
    Oct 2007
    I got the same issue as urs, but not the same solution i think!
    I am also getting one colum...
    http://trendyhandbags.co.uk/leather-c-40.html
    Any ideas?
    Quote Originally Posted by CiriusRizk View Post
  9. #19
    You are getting the table heading output for the stock "rows" layout:
    Product Image
    Item Name-
    Price
    which should not appear if you are using the Column Grid files.
    Did you double check that all of the mod files are in the correct places, and that they are actually full files and not empty shells?
  1. [problem] Column Layout Grid
    By kitkitng in forum All Other Contributions/Addons
    Last Post: 8 Jun 2011, 01:01 PM
  2. Firefox vs IE layout problem ... ff = column, IE = grid ??
    By NazarHookah in forum Templates, Stylesheets, Page Layout
    Last Post: 1 Jan 2009, 12:03 PM
  3. Problem with column layout grid
    By erezw in forum Templates, Stylesheets, Page Layout
    Last Post: 14 Nov 2008, 10:35 PM
  4. Column Layout Grid problem
    By djcaw57 in forum General Questions
    Last Post: 29 Sep 2008, 02:57 PM
  5. Column Grid Layout on 1.3.7 (single column problem)
    By Taipa in forum All Other Contributions/Addons
    Last Post: 12 May 2007, 11:44 AM
