Results 1 to 10 of 16
    Sep 2007
    Default UPS Heavy Freight Module UPS Freight over 150 lbs.
    Copyright 2007 Distributed under the terms of the GNUv3 General Public License .
    UPS XML-RPC Interface is a simple XML-RPC
    service for connecting to UPS for shipping estimates.
    UPS XML-RPC Interface is written in PHP,
    but can be accessed by any program
    that can communicate with XML-RPC.
    Here is the UPS side of the Module.
    We have been looking for this for a long time.
    A proper Module needs to be created.
    let us all get behind this one and push.
    --Links you will need, these libraries must be installed,
    in your server.
    http://phpxmlrpc.sourceforge.net/
    http://sourceforge.net/projects/expat/
    Sep 2007
    Default Re: UPS Heavy Freight Module UPS Freight over 150 lbs.
    Zen Cart UPS Heavy Freight Module
    The other two Heavy Freight Modules,
    are at these links,
    with one class of Freight they are sign up and use.
    FedEx Heavy Freight Module:
    http://www.zen-cart.com/forum/showthread.php?t=88424
    Con-Way Heavy Freight Module:
    http://www.zen-cart.com/forum/showth...reate+a+module
    Build a Zen Cart UPS Heavy Freight Module
    This is from a get's quotes from UPS working website.
    --Start:
    UPS XML-RPC Interface is released under the GPLv3 license.
    This is a first stab at creating an easy-to-use,
    language neutral, interface for getting a shipping estimate from UPS.
    So far it seems to work perfectly for our needs but bugs are likely.
    To install the UPS XML-RPC interface you'll need to compile Apache with CURL,
    expat, and XML-RPC.
    You'll need this on the server you're running
    the UPS XML-RPC interface on and,
    if different, also on the server your application is running on.
    In your PHP application you'll need a function to make XML-RPC requests.
    I've provided an example below.
    Any programming language that can make XML-RPC requests
    can make requests of the UPS XML-RPC interface in a similar way.
    function remoteRequest ( $server, $method, $params ) {
    $req = xmlrpc_encode_request ( $method, $params );
    $headers = array (
    'Content-Type: text/xml',
    'Content-Length: ' . strlen ( $req )
    $ch = curl_init ( "http://$server/" );
    curl_setopt ( $ch, CURLOPT_RETURNTRANSFER, True );
    curl_setopt ( $ch, CURLOPT_HTTPHEADER, $headers );
    curl_setopt ( $ch, CURLOPT_CUSTOMREQUEST, 'POST' );
    curl_setopt ( $ch, CURLOPT_POSTFIELDS, $req );
    curl_setopt ( $ch, CURLOPT_TIMEOUT, 600 );
    set_time_limit ( 600 );
    $resp = curl_exec ( $ch );
    set_time_limit ( 30 );
    curl_close ( $ch );
    return xmlrpc_decode ( $resp );
    The structure of the XML-RPC request,
    is very similar to the XML requests documented in the
    'UPS OnLine Tools Rates and Service Selection Developers Guide'.
    $resp = remoteRequest ( 'ups', 'ratingServiceSelectionRequest', $upsParams );
    From your PHP application you can connect to a server,
    'ups', and run the function, 'ratingServiceSelectionRequest',
    with the options defined in an array, $upsParams.
    The result will be returned as the $resp array.
    To define your array that you'll submit there are several common options.
    You'll need a UPS shipper number, access key, username, and password.
    You'll also need to know the shipper's postal code, state code,
    and country code and the destination postal code, state code, and country code.
    You'll need to define one or more packages.
    Shipments of more than 150lbs will need to go by UPS Freight.
    Smaller packages can be shipped by UPS Ground but must be calculated separately.
    Below is a sample package definition.
    You can define the dimensions of the package if you know them,
    for a more accurate shipping estimate.
    One or more packages should be put into a $packages array.
    $package = array (
    'packagingType' => array (
    'code' => '02' // Customer supplied packaging.
    'dimensions' => array (
    'unitOfMeasurement' => array (
    'code' => 'IN'
    'length' => 1,
    'width' => 1,
    'height' => 1
    'packageWeight' => array (
    'code' => 'LBS'
    'weight' => $weight
    Below is an example of a full options array.
    $upsParams = array (
    'accessKey' => UPS_ACCESS_KEY,
    'username' => UPS_USERNAME,
    'password' => UPS_PASSWORD,
    'request' => array (
    'requestAction' => 'rate',
    'requestOption' => 'Rate'
    'pickupType' => array (
    'code' => '03' // customer counter
    'customerClassification' => array (
    'code' => '04' // retail
    'shipment' => array (
    'service' => array (
    'code' => $service // UPS Freight (308) or UPS Ground (03)
    'shipper' => array (
    'shipperNumber' => UPS_SHIP_NUMBER,
    'address' => array (
    'postalCode' => UPS_SHIPPER_POSTAL,
    'stateProvinceCode' => UPS_SHIPPER_STATE,
    'countryCode' => UPS_SHIPPER_COUNTRY
    'shipTo' => array (
    'postalCode' => $postalCode,
    'stateProvinceCode' => $state,
    'countryCode' => $country
    'packages' => $packages
    You'll need to check your response array to see if your request succeeded.
    If so, you'll probably want to add up all the charges.
    Otherwise you'll want to respond to the error in some way.
    Sample code to do this is below.
    if ( $resp['response']['responseStatusCode'] == 1 ) {
    $shipping = 0.00;
    foreach ( $resp['ratedShipments'] as $ratedShipment ) {
    $shipping = $shipping + (float) $ratedShipment['totalCharges']['monetaryValue'];
    // an error has occured. do something.
    Now you have a good estimate of the shipping charges. Add your handling fee and you're done.
    Sep 2007
    Ups Heavy Freight Module Freight over 150 lbs.
    The UPS side of the Module let us build,
    a UPS Heavy Freight Module for Freight over 150 lbs
    ---Starts the long version
    ups_xmlrpc_interface/ $xml ) {
    $this->xmlParser ( $xml );
    // Response
    if ( list ( $response, ) = $this->getElementsByTag ( 'Response' ) ) {
    // TransactionReference
    if ( list ( $transactionReference, ) = $response->getChildrenByTag ( 'TransactionReference' ) ) {
    $tRef = array ();
    if ( list ( $customerContext, ) = $transactionReference->getChildrenByTag ( 'CustomerContext' ) ) {
    $tRef['customerContext'] = $customerContext->getCdata ();
    if ( list ( $xpciVersion, ) = $transactionReference->getChildrenByTag ( 'XpciVersion' ) ) {
    $tRef['xpciVersion'] = $xpciVersion->getCdata ();
    $this->response['transactionReference'] = $tRef;
    // ResponseStatusCode
    list ( $responseStatusCode, ) = $response->getChildrenByTag ( 'ResponseStatusCode' );
    $this->response['responseStatusCode'] = $responseStatusCode->getCdata ();
    // ResponseStatusDescription
    if ( list ( $responseStatusDescription, ) = $response->getChildrenByTag ( 'ResponseStatusDescription' ) ) {
    $this->response['responseStatusDescription'] = $responseStatusDescription->getCdata ();
    // Errors
    if ( $errors = $response->getChildrenByTag ( 'Error' ) ) {
    $errs = array ();
    foreach ( $errors as $error ) {
    $err = array ();
    list ( $errorSeverity, ) = $error->getChildrenByTag ( 'ErrorSeverity' );
    $err['errorSeverity'] = $errorSeverity->getCdata ();
    list ( $errorCode, ) = $error->getChildrenByTag ( 'ErrorCode' );
    $err['errorCode'] = $errorCode->getCdata ();
    if ( list ( $errorDescription, ) = $error->getChildrenByTag ( 'ErrorDescription' ) ) {
    $err['errorDescription'] = $errorDescription->getCdata ();
    if ( list ( $minimumRetrySeconds, ) = $error->getChildrenByTag ( 'MinimumRetrySeconds' ) ) {
    $err['minimumRetrySeconds'] = $minimumRetrySeconds->getCdata ();
    if ( $errorLocations = $error->getChildrenByTag ( 'ErrorLocation' ) ) {
    $errLocs = array ();
    foreach ( $errorLocations as $errorLocation ) {
    $errLoc = array ();
    if ( list ( $errorLocationElementName, ) = $errorLocation->getChildrenByTag ( 'ErrorLocationElementName' ) ) {
    $errLoc['errorLocationElementName'] = $errorLocationElementName->getCdata ();
    if ( list ( $errorLocationElementReference, ) = $errorLocation->getChildrenByTag ( 'ErrorLocationElementReference' ) ) {
    $errLoc['errorLocationElementReference'] = $errorLocationElementReference->getCdata ();
    if ( list ( $errorLocationAttributeName, ) = $errorLocation->getChildrenByTag ( 'ErrorLocationAttributeName' ) ) {
    $errLoc['errorLocationAttributeName'] = $errorLocationAttributeName->getCdata ();
    $errLocs[] = $errLoc;
    $err['errorLocations'] = $errLocs;
    if ( $errorDigests = $error->getChildrenByTag ( 'ErrorDigest' ) ) {
    $errDigs = array ();
    foreach ( $errorDigests as $errorDigest ) {
    $errDigs[] = $errorDigest->getCdata ();
    $err['errorDigests'] = $errDigs;
    $errs[] = $err;
    $this->response['errors'] = $errs;
    // RatedShipments
    if ( $ratedShipments = $this->getElementsByTag ( 'RatedShipment' ) ) {
    $ships = array ();
    foreach ( $ratedShipments as $ratedShipment ) {
    $ship = array ();
    // Service
    list ( $service, ) = $ratedShipment->getChildrenByTag ( 'Service' );
    $srv = array ();
    list ( $code, ) = $service->getChildrenByTag ( 'Code' );
    $srv['code'] = $code->getCdata ();
    if ( list ( $description, ) = $ratedShipment->getChildrenByTag ( 'Description' ) ) {
    $srv['description'] = $description->getCdata ();
    $ship['service'] = $srv;
    // RatedShipmentWarnings
    if ( $ratedShipmentWarnings = $ratedShipment->getChildrenByTag ( 'RatedShipmentWarning' ) ) {
    $warnings = array ();
    foreach ( $ratedShipmentWarnings as $ratedShipmentWarning ) {
    $warnings[] = $ratedShipmentWarning->getCdata ();
    $ship['ratedShipmentWarnings'] = $warnings;
    // BillingWeight
    if ( list ( $billingWeight, ) = $ratedShipment->getChildrenByTag ( 'BillingWeight' ) ) {
    $bw = array ();
    list ( $unitOfMeasurement, ) = $billingWeight->getChildrenByTag ( 'UnitOfMeasurement' );
    $uom = array ();
    list ( $code, ) = $unitOfMeasurement->getChildrenByTag ( 'Code' );
    $uom['code'] = $code->getCdata ();
    if ( list ( $description, ) = $unitOfMeasurement->getChildrenByTag ( 'Description' ) ) {
    $uom['description'] = $description->getCdata ();
    $bw['unitOfMeasurement'] = $uom;
    list ( $weight, ) = $billingWeight->getChildrenByTag ( 'Weight' );
    $bw['weight'] = $weight->getCdata ();
    $ship['billingWeight'] = $bw;
    // TransportationCharges
    list ( $transportationCharges, ) = $ratedShipment->getChildrenByTag ( 'TransportationCharges' );
    $tChrg = array ();
    if ( list ( $currencyCode, ) = $transportationCharges->getChildrenByTag ( 'CurrencyCode' ) ) {
    $tChrg['currencyCode'] = $currencyCode->getCdata ();
    list ( $monetaryValue, ) = $transportationCharges->getChildrenByTag ( 'MonetaryValue' );
    $tChrg['monetaryValue'] = $monetaryValue->getCdata ();
    $ship['transportationCharges'] = $tChrg;
    // ServiceOptionsCharges
    if ( list ( $serviceOptionsCharges, ) = $ratedShipment->getChildrenByTag ( 'ServiceOptionsCharges' ) ) {
    $sChrg = array ();
    if ( list ( $currencyCode, ) = $serviceOptionsCharges->getChildrenByTag ( 'CurrencyCode' ) ) {
    $sChrg['currencyCode'] = $currencyCode->getCdata ();
    list ( $monetaryValue, ) = $serviceOptionsCharges->getChildrenByTag ( 'MonetaryValue' );
    $sChrg['monetaryValue'] = $monetaryValue->getCdata ();
    $ship['serviceOptionsCharges'] = $sChrg;
    // HandlingChargeAmount
    if ( list ( $handlingChargeAmount, ) = $ratedShipment->getChildrenByTag ( 'HandlingChargeAmount' ) ) {
    $hChrg = array ();
    if ( list ( $currencyCode, ) = $handlingChargeAmount->getChildrenByTag ( 'CurrencyCode' ) ) {
    $hChrg['currencyCode'] = $currencyCode->getCdata ();
    list ( $monetaryValue, ) = $handlingChargeAmount->getChildrenByTag ( 'MonetaryValue' );
    $hChrg['monetaryValue'] = $monetaryValue->getCdata ();
    $ship['serviceOptionsCharges'] = $hChrg;
    // TotalCharges
    list ( $totalCharges, ) = $ratedShipment->getChildrenByTag ( 'TotalCharges' );
    $tChrg = array ();
    if ( list ( $currencyCode, ) = $totalCharges->getChildrenByTag ( 'CurrencyCode' ) ) {
    list ( $monetaryValue, ) = $totalCharges->getChildrenByTag ( 'MonetaryValue' );
    $ship['totalCharges'] = $tChrg;
    // GuaranteedDaysToDelivery
    list ( $guaranteedDaysToDelivery, ) = $ratedShipment->getChildrenByTag ( 'GuaranteedDaysToDelivery' );
    $ship['guaranteedDaysToDelivery'] = $guaranteedDaysToDelivery->getCdata ();
    // ScheduledDeliveryTime
    list ( $scheduledDeliveryTime, ) = $ratedShipment->getChildrenByTag ( 'ScheduledDeliveryTime' );
    $ship['scheduledDeliveryTime'] = $scheduledDeliveryTime->getCdata ();
    // RatedPackages
    $ratedPackages = $ratedShipment->getChildrenByTag ( 'RatedPackage' );
    $pkgs = array ();
    foreach ( $ratedPackages as $ratedPackage ) {
    $pkg = array ();
    list ( $transportationCharges, ) = $ratedPackage->getChildrenByTag ( 'TransportationCharges' );
    $tChrg = array ();
    $pkg['transportationCharges'] = $tChrg;
    if ( list ( $serviceOptionsCharges, ) = $ratedPackage->getChildrenByTag ( 'ServiceOptionsCharges' ) ) {
    $sChrg = array ();
    $pkg['serviceOptionsCharges'] = $sChrg;
    list ( $totalCharges, ) = $ratedPackage->getChildrenByTag ( 'TotalCharges' );
    $tChrg = array ();
    $pkg['totalCharges'] = $tChrg;
    list ( $weight, ) = $ratedPackage->getChildrenByTag ( 'Weight' );
    $pkg['weight'] = $weight->getCdata ();
    if ( list ( $billingWeight, ) = $ratedPackage->getChildrenByTag ( 'BillingWeight' ) ) {
    $bw = array ();
    $uom = array ();
    $pkg['billingWeight'] = $bw;
    $pkgs[] = $pkg;
    $ship['ratedPackages'] = $pkgs;
    // NegotiatedRates
    if ( list ( $negotiatedRates, ) = $ratedShipment->getChildrenByTag ( 'NegotiatedRates' ) ) {
    $neg = array ();
    list ( $netSummaryCharges, ) = $negotiatedRates->getChildrenByTag ( 'NetSummaryCharges' );
    $net = array ();
    list ( $grandTotal, ) = $netSummaryCharges->getChildrenByTag ( 'GrandTotal' );
    $total = array ();
    list ( $currencyCode, ) = $grandTotal->getChildrenByTag ( 'CurrencyCode' );
    $total['currencyCode'] = $currencyCode->getCdata ();
    list ( $monetaryValue, ) = $grandTotal->getChildrenByTag ( 'MonetaryValue' );
    $total['monetaryValue'] = $monetaryValue->getCdata ();
    $net['grandTotal'] = $total;
    $neg['netSummaryCharges'] = $net;
    $ship['negotiatedRates'] = $neg;
    $ships[] = $ship;
    $this->ratedShipments = $ships;
    function getResponse () {
    return $this->response;
    function getRatedShipments () {
    return $this->ratedShipments;
    Sep 2007
    <? // Copyright 2007 Distributed under the terms of the GNU General Public License version 3.
    This file is part of UPS XML-RPC Interface.
    UPS XML-RPC is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by the
    Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    UPS XML-RPC is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with UPS XML-RPC. If not, see <http://www.gnu.org/licenses/>.
    class xmlObject {
    var $tag;
    var $attributes;
    var $children;
    function xmlObject ( $tag, $attributes = Null, $children = Null ) {
    $this->tag = $tag;
    $this->attributes = $attributes ? $attributes : array ();
    $this->children = $children ? $children : array ();
    function getTag () {
    return $this->tag;
    function setTag ( $tag ) {
    $this->tag = $tag;
    function getAttributes () {
    return $this->attributes;
    function getAttribute ( $var ) {
    return $this->attributes[$var];
    function setAttribute ( $var, $value ) {
    $this->attributes[$var] = $value;
    function unsetAttribute ( $var ) {
    unset ( $this->attributes[$var] );
    function getChildren () {
    return $this->children;
    function appendChild ( $child ) {
    $this->children[] = $child;
    function appendChildren ( $children ) {
    foreach ( $children as $child ) {
    $this->appendChild ( $child );
    function getChildrenByTag ( $tag ) {
    $elements = array ();
    if ( $this->children ) {
    foreach ( $this->children as $child ) {
    if ( $child->tag && $child->tag == $tag ) {
    $elements[] = $child;
    return $elements;
    function getCdata () {
    $cdata = array ();
    if ( $child->cdata != '' ) {
    $cdata[] = $child->cdata;
    return implode ( ' ', $cdata );
    function xmlAttributes () {
    $attribs = array ();
    if ( $this->attributes ) {
    while ( list ( $var, $value ) = each ( $this->attributes ) ) {
    $attribs[] = "$var=\"$value\"";
    return implode ( ' ', $attribs );
    function xmlChildren () {
    $xml = '';
    if ( isset ( $child->cdata ) ) {
    $xml .= $child->xml ();
    $cEnd = True;
    foreach ( explode ( "\n", $child->xml () ) as $line ) {
    $xml .= "\n $line";
    $cEnd = False;
    if ( ! $cEnd ) {
    $xml = "$xml\n";
    return $xml;
    function xml () {
    $xmlTag = $this->tag;
    $xmlAttributes = $this->xmlAttributes ();
    $xmlChildren = $this->xmlChildren ();
    if ( isset ( $xmlChildren ) ) {
    $xml = $xmlAttributes ? "<$xmlTag $xmlAttributes>$xmlChildren</$xmlTag>" :"<$xmlTag>$xmlChildren</$xmlTag>" ;
    $xml = $xmlAttributes ? "<$xmlTag $xmlAttributes/>" : "<$xmlTag/>";
    return $xml;
    function xmlDocument () {
    $xml = $this->xml ();
    $doc = <<<EndDoc
    <?xml version="1.0" ?>
    $xml
    EndDoc;
    return $doc;
    class cdataObject {
    var $cdata;
    function cdataObject ( $cdata ) {
    $this->cdata = $cdata;
    function xml () {
    return $this->cdata;
    class combinedObject extends xmlObject {
    function combinedObject ( $tag, $cdata, $attributes = Null ) {
    $this->xmlObject ( $tag, $attributes );
    $this->appendChild ( new cdataObject ( $cdata ) );
    class doubleCombinedObject extends xmlObject {
    function doubleCombinedObject ( $tag1, $tag2, $cdata ) {
    $this->xmlObject ( $tag1 );
    $this->appendChild ( new combinedObject ( $tag2, $cdata ) );
    curl_close ( $ch );
    The structure of the XML-RPC request is very similar to the XML
    requests documented in the 'UPS OnLine Tools Rates and Service
    From your PHP application you can connect to a server, 'ups', and run
    the function, 'ratingServiceSelectionRequest', with the options defined
    in an array, $upsParams. The result will be returned as the $resp
    array.
    options. You'll need a UPS shipper number, access key, username, and
    password. You'll also need to know the shipper's postal code, state
    code, and country code and the destination postal code, state code, and
    country code.
    You'll need to define one or more packages. Shipments of more than
    150lbs will need to go by UPS Freight. Smaller packages can be shipped
    Below is a sample package definition. You can define the dimensions of
    the package if you know them for a more accurate shipping estimate. One
    $package = array (
    'code' => 'IN'
    'length' => 1,
    'width' => 1,
    'height' => 1
    'code' => 'LBS'
    'weight' => $weight
    'shipTo' => array (
    succeeded. If so, you'll probably want to add up all the charges.
    Otherwise you'll want to respond to the error in some way. Sample code
    $shipping = 0.00;
    Sep 2007
    eNumber = new combinedObject ( 'PhoneLineNumber', $shipmnt['shipper']['phoneNumber']['phoneLineNumber'] );
    $structuredPhoneNumber = new xmlObject ( 'StructuredPhoneNumber', Null, array ( $phoneDialPlanNumber, $phoneLinenumber ) );
    $phoneNumber = new xmlObject ( 'PhoneNumber', Null, array ( $structuredPhoneNumber ) );
    if ( $shipmnt['shipper']['phoneNumber']['phoneCountryCode'] ) {
    $phoneCountryCode = new combinedObject ( 'PhoneCountryCode', $shipmnt['shipper']['phoneNumber']['phoneCountryCode'] );
    $structuredPhoneNumber->appendChild ( $phoneCountryCode );
    if ( $shipmnt['shipper']['phoneNumber']['phoneExtension'] ) {
    $phoneExtension = new combinedObject ( 'PhoneExtension', $shipmnt['shipper']['phoneNumber']['phoneExtension'] );
    $structuredPhoneNumber->appendChild ( $phoneExtension );
    $phoneNumber = new combinedObject ( 'PhoneNumber', $shipmnt['shipper']['phoneNumber'] );
    $shipper->appendChild ( $phoneNumber );
    if ( $shipmnt['shipper']['faxNumber'] ) {
    $faxNumber = new combinedObject ( 'FaxNumber', $shipmnt['shipper']['faxNumber'] );
    $shipper->appendChild ( $faxNumber );
    if ( $shipmnt['shipper']['shipperNumber'] ) {
    $shipperNumber = new combinedObject ( 'ShipperNumber', $shipmnt['shipper']['shipperNumber'] );
    $shipper->appendChild ( $shipperNumber );
    if ( $shipmnt['shipper']['address'] ) {
    $countryCode = new combinedObject ( 'CountryCode', $shipmnt['shipper']['address']['countryCode'] );
    $address = new xmlObject ( 'Address', Null, array ( $countryCode ) );
    if ( $shipmnt['shipper']['address']['addressLine1'] ) {
    $addressLine1 = new combinedObject ( 'AddressLine1', $shipmnt['shipper']['address']['addressLine1'] );
    $address->appendChild ( $addressLine1 );
    if ( $shipmnt['shipper']['address']['addressLine2'] ) {
    $addressLine2 = new combinedObject ( 'AddressLine2', $shipmnt['shipper']['address']['addressLine2'] );
    $address->appendChild ( $addressLine2 );
    if ( $shipmnt['shipper']['address']['addressLine3'] ) {
    $addressLine3 = new combinedObject ( 'AddressLine3', $shipmnt['shipper']['address']['addressLine3'] );
    $address->appendChild ( $addressLine3 );
    if ( $shipmnt['shipper']['address']['city'] ) {
    $city = new combinedObject ( 'City', $shipmnt['shipper']['address']['city'] );
    $address->appendChild ( $city );
    if ( $shipmnt['shipper']['address']['stateProvinceCode'] ) {
    $stateProvinceCode = new combinedObject ( 'StateProvinceCode', $shipmnt['shipper']['address']['stateProvinceCode'] );
    $address->appendChild ( $stateProvinceCode );
    if ( $shipmnt['shipper']['address']['postalCode'] ) {
    $postalCode = new combinedObject ( 'PostalCode', $shipmnt['shipper']['address']['postalCode'] );
    $address->appendChild ( $postalCode );
    if ( $shipmnt['shipper']['address']['residentialAddress'] ) {
    $residentialAddress = new combinedObject ( 'ResidentialAddress', $shipmnt['shipper']['address']['residentialAddress'] );
    $address->appendChild ( $residentialAddress );
    if ( $shipmnt['shipper']['address']['residentialAddressIndicator'] ) {
    $residentialAddressIndicator = new combinedObject ( 'ResidentialAddressIndicator', $shipmnt['shipper']['address']['residentialAddressIndicator'] );
    $address->appendChild ( $residentialAddressIndicator );
    $shipper->appendChild ( $address );
    // ShipTo
    $countryCode = new combinedObject ( 'CountryCode', $shipmnt['shipTo']['address']['countryCode'] );
    if ( $shipmnt['shipTo']['address']['addressLine1'] ) {
    $addressLine1 = new combinedObject ( 'AddressLine1', $shipmnt['shipTo']['address']['addressLine1'] );
    if ( $shipmnt['shipTo']['address']['addressLine2'] ) {
    $addressLine2 = new combinedObject ( 'AddressLine2', $shipmnt['shipTo']['address']['addressLine2'] );
    if ( $shipmnt['shipTo']['address']['addressLine3'] ) {
    $addressLine3 = new combinedObject ( 'AddressLine3', $shipmnt['shipTo']['address']['addressLine3'] );
    if ( $shipmnt['shipTo']['address']['city'] ) {
    $city = new combinedObject ( 'City', $shipmnt['shipTo']['address']['city'] );
    if ( $shipmnt['shipTo']['address']['stateProvinceCode'] ) {
    $stateProvinceCode = new combinedObject ( 'StateProvinceCode', $shipmnt['shipTo']['address']['stateProvinceCode'] );
    if ( $shipmnt['shipTo']['address']['postalCode'] ) {
    $postalCode = new combinedObject ( 'PostalCode', $shipmnt['shipTo']['address']['postalCode'] );
    if ( $shipmnt['shipTo']['address']['residentialAddress'] ) {
    $residentialAddress = new combinedObject ( 'ResidentialAddress', $shipmnt['shipTo']['address']['residentialAddress'] );
    if ( $shipmnt['shipTo']['address']['residentialAddressIndicator'] ) {
    $residentialAddressIndicator = new combinedObject ( 'ResidentialAddressIndicator', $shipmnt['shipTo']['address']['residentialAddressIndicator'] );
    $shipTo = new xmlObject ( 'ShipTo', Null, array ( $address ) );
    if ( $shipmnt['shipTo']['shipperAssignedIdentificationNumber'] ) {
    $shipperAssignedIdentificationNumber = new combinedObject ( 'ShipperAssignedIdentificationNumber', $shipmnt['shipTo']['shipperAssignedIdentificationNumber'] );
    $shipTo->appendChild ( $shipperAssignedIdentificationNumber );
    if ( $shipmnt['shipTo']['companyName'] ) {
    $companyName = new combinedObject ( 'CompanyName', $shipmnt['shipTo']['companyName'] );
    $shipTo->appendChild ( $companyName );
    if ( $shipmnt['shipTo']['attentionName'] ) {
    $attentionName = new combinedObject ( 'AttentionName', $shipmnt['shipTo']['attentionName'] );
    $shipTo->appendChild ( $attentionName );
    if ( $shipmnt['shipTo']['phoneNumber'] ) {
    if ( is_array ( $shipmnt['shipTo']['phoneNumber'] ) ) {
    $phoneDialPlanNumber = new combinedObject ( 'PhoneDialPlanNumber', $shipmnt['shipTo']['phoneNumber']['phoneDialPlanNumber'] );
    $phoneLineNumber = new combinedObject ( 'PhoneLineNumber', $shipmnt['shipTo']['phoneNumber']['phoneLineNumber'] );
    if ( $shipmnt['shipTo']['phoneNumber']['phoneCountryCode'] ) {
    $phoneCountryCode = new combinedObject ( 'PhoneCountryCode', $shipmnt['shipTo']['phoneNumber']['phoneCountryCode'] );
    if ( $shipmnt['shipTo']['phoneNumber']['phoneExtension'] ) {
    $phoneExtension = new combinedObject ( 'PhoneExtension', $shipmnt['shipTo']['phoneNumber']['phoneExtension'] );
    $phoneNumber = new combinedObject ( 'PhoneNumber', $shipmnt['shipTo']['phoneNumber'] );
    if ( $shipmnt['shipTo']['taxIdentificationNumber'] ) {
    $taxIdentificationNumber = new combinedObject ( 'TaxIdentificationNumber', $shipmnt['shipTo']['taxIdentificationNumber'] );
    $shipTo->appendChild ( $taxIdentificationNumber );
    if ( $shipmnt['shipTo']['faxNumber'] ) {
    $faxNumber = new combinedObject ( 'FaxNumber', $shipmnt['shipTo']['faxNumber'] );
    $shipTo->appendChild ( $faxNumber );
    if ( $shipmnt['shipTo']['locationId'] ) {
    $locationId = new combinedObject ( 'LocationID', $shipmnt['shipTo']['locationId'] );
    $shipTo->appendChild ( $locationId );
    $shipment = new xmlObject ( 'Shipment', Null, array ( $shipper, $shipTo ) );
    // Description
    if ( $shipmnt['description'] ) {
    $description = new combinedObject ( 'Description', $shipmnt['description'] );
    $shipment->appendChild ( $description );
    // ShipFrom
    if ( $shipmnt['shipFrom'] ) {
    $companyName = new combinedObject ( 'CompanyName', $shipmnt['shipFrom']['companyName'] );
    if ( is_array ( $shipmnt['shipFrom']['phoneNumber'] ) ) {
    $phoneDialPlanNumber = new combinedObject ( 'PhoneDialPlanNumber', $shipmnt['shipFrom']['phoneNumber']['phoneDialPlanNumber'] );
    $phoneLineNumber = new combinedObject ( 'PhoneLineNumber', $shipmnt['shipFrom']['phoneNumber']['phoneLineNumber'] );
    if ( $shipmnt['shipFrom']['phoneNumber']['phoneCountryCode'] ) {
    $phoneCountryCode = new combinedObject ( 'PhoneCountryCode', $shipmnt['shipFrom']['phoneNumber']['phoneCountryCode'] );
    if ( $shipmnt['shipFrom']['phoneNumber']['phoneExtension'] ) {
    $phoneExtension = new combinedObject ( 'PhoneExtension', $shipmnt['shipFrom']['phoneNumber']['phoneExtension'] );
    $phoneNumber = new combinedObject ( 'PhoneNumber', $shipmnt['shipFrom']['phoneNumber'] );
    $countryCode = new combinedObject ( 'CountryCode', $shipmnt['shipFrom']['address']['countryCode'] );
    if ( $shipmnt['shipFrom']['address']['addressLine1'] ) {
    $addressLine1 = new combinedObject ( 'AddressLine1', $shipmnt['shipFrom']['address']['addressLine1'] );
    if ( $shipmnt['shipFrom']['address']['addressLine2'] ) {
    $addressLine2 = new combinedObject ( 'AddressLine2', $shipmnt['shipFrom']['address']['addressLine2'] );
    if ( $shipmnt['shipFrom']['address']['addressLine3'] ) {
    $addressLine3 = new combinedObject ( 'AddressLine3', $shipmnt['shipFrom']['address']['addressLine3'] );
    if ( $shipmnt['shipFrom']['address']['city'] ) {
    $city = new combinedObject ( 'City', $shipmnt['shipFrom']['address']['city'] );
    if ( $shipmnt['shipFrom']['address']['stateProvinceCode'] ) {
    $stateProvinceCode = new combinedObject ( 'StateProvinceCode', $shipmnt['shipFrom']['address']['stateProvinceCode'] );
    if ( $shipmnt['shipFrom']['address']['postalCode'] ) {
    $postalCode = new combinedObject ( 'PostalCode', $shipmnt['shipFrom']['address']['postalCode'] );
    if ( $shipmnt['shipFrom']['address']['residentialAddress'] ) {
    $residentialAddress = new combinedObject ( 'ResidentialAddress', $shipmnt['shipFrom']['address']['residentialAddress'] );
    if ( $shipmnt['shipFrom']['address']['residentialAddressIndicator'] ) {
    $residentialAddressIndicator = new combinedObject ( 'ResidentialAddressIndicator', $shipmnt['shipFrom']['address']['residentialAddressIndicator'] );
    $shipFrom = new xmlObject ( 'ShipFrom', Null, array ( $companyName, $phoneNumber, $address ) );
    if ( $shipmnt['shipFrom']['attentionName'] ) {
    $attentionName = new combinedObject ( 'AttentionName', $shipmnt['shipFrom']['attentionName'] );
    $shipFrom->appendChild ( $attentionName );
    if ( $shipmnt['shipFrom']['faxNumber'] ) {
    $faxNumber = new combinedObject ( 'FaxNumber', $shipmnt['shipFrom']['faxNumber'] );
    $shipFrom->appendChild ( $faxNumber );
    $shipment->appendChild ( $shipFrom );
    // ShipmentWeight
    if ( $shipmnt['shipmentWeight'] ) {
    $code = new combinedObject ( 'Code', $shipmnt['shipmentWeight']['code'] );
    $weight = new combinedObject ( 'Weight', $shipmnt['shipmentWeight']['weight'] );
    $unitOfMeasurement = new xmlObject ( 'UnitOfMeasurement', Null, array ( $code, $weight ) );
    $shipmentWeight = new xmlObject ( 'ShipmentWeight', Null, array ( $unitOfMeasurement ) );
    if ( $shipmnt['shipmentWeight']['description'] ) {
    $description = new combinedObject ( 'Description', $shipmnt['shipmentWeight']['description'] );
    $shipmentWeight->appendChild ( $description );
    $shipment->appendChild ( $shipmentWeight );
    // ReferenceNumber
    if ( $shipmnt['referenceNumber'] ) {
    $code = new combinedObject ( 'Code', $shipmnt['referenceNumber']['code'] );
    $value = new combinedObject ( 'Value', $shipmnt['referenceNumber']['value'] );
    $referenceNumber = new xmlObject ( 'ReferenceNumber', Null, array ( $code, $value ) );
    $shipment->appendChild ( $referenceNumber );
    // Service
    if ( $shipmnt['service'] ) {
    $code = new combinedObject ( 'Code', $shipmnt['service']['code'] );
    $service = new xmlObject ( 'Service', Null, array ( $code ) );
    if ( $shipmnt['service']['description'] ) {
    $description = new combinedObject ( 'Description', $shipmnt['service']['description'] );
    $service->appendChild ( $description );
    $shipment->appendChild ( $service );
    // PickupDate
    if ( $shipmnt['pickupDate'] ) {
    $pickupDate = new combinedObject ( 'PickupDate', $shipmnt['pickupDate'] );
    $shipment->appendChild ( $pickupDate );
    // ScheduledDeliveryDate
    if ( $shipmnt['scheduledDeliveryDate'] ) {
    $scheduledDeliveryDate = new combinedObject ( 'ScheduledDeliveryDate', $shipmnt['scheduledDeliveryDate'] );
    $shipment->appendChild ( $scheduledDeliveryDate );
    if ( $shipmnt['scheduledDeliveryTime'] ) {
    $scheduledDeliveryTime = new combinedObject ( 'ScheduledDeliveryTime', $shipmnt['scheduledDeliveryTime'] );
    $shipment->appendChild ( $scheduledDeliveryTime );
    // AlternateDeliveryTime
    if ( $shipmnt['alternateDeliveryTime'] ) {
    $alternateDeliveryTime = new combinedObject ( 'AlternateDeliveryTime', $shipmnt['alternateDeliveryTime'] );
    $shipment->appendChild ( $alternateDeliveryTime );
    // DocumentsOnly
    if ( $shipmnt['documentsOnly'] ) {
    $documentsOnly = new combinedObject ( 'DocumentsOnly', $shipmnt['documentsOnly'] );
    $shipment->appendChild ( $documentsOnly );
    Sep 2007
    // Packages
    if ( $shipmnt['packages'] ) {
    foreach ( $shipmnt['packages'] as $pkg ) {
    $package = new xmlObject ( 'Package' );
    if ( $pkg['packagingType'] ) {
    $code = new CombinedObject ( 'Code', $pkg['packagingType']['code'] );
    $packagingType = new xmlObject ( 'PackagingType', Null, array ( $code ) );
    if ( $pkg['packagingType']['description'] ) {
    $description = new combinedObject ( 'Description', $pkg['packagingType']['description'] );
    $packagingType->appendChild ( $description );
    $package->appendChild ( $packagingType );
    if ( $pkg['description'] ) {
    $description = new combinedObject ( 'Description', $pkg['description'] );
    $package->appendChild ( $description );
    if ( $pkg['dimensions'] ) {
    $length = new combinedObject ( 'Length', $pkg['dimensions']['length'] );
    $width = new combinedObject ( 'Width', $pkg['dimensions']['width'] );
    $height = new combinedObject ( 'Height', $pkg['dimensions']['height'] );
    $dimensions = new xmlObject ( 'Dimensions', Null, array ( $length, $width, $height ) );
    if ( $pkg['dimensions']['unitOfMeasurement'] ) {
    $code = new combinedObject ( 'Code', $pkg['dimensions']['unitOfMeasurement']['code'] );
    $unitOfMeasurement = new xmlObject ( 'UnitOfMeasurement', Null, array ( $code ) );
    if ( $pkg['dimensions']['unitOfMeasurement']['description'] ) {
    $description = new combinedObject ( 'Description', $pkg['dimensions']['unitOfMeasurement']['description'] );
    $unitOfMeasurement->appendChild ( $description );
    $dimensions->appendChild ( $unitOfMeasurement );
    $package->appendChild ( $dimensions );
    if ( $pkg['dimensionalWeight'] ) {
    if ( $pkg['dimensionalWeight']['unitOfMeasurement'] ) {
    $code = new combinedObject ( 'Code', $pkg['dimensionalWeight']['unitOfMeasurement']['code'] );
    if ( $pkg['dimensionalWeight']['unitOfMeasurement']['description'] ) {
    $description = new combinedObject ( 'Description', $pkg['dimensionalWeight']['unitOfMeasurement']['description'] );
    $weight = new combinedObject ( 'Weight', $pkg['dimensionalWeight']['weight'] );
    $dimensionalWeight = new xmlObject ( 'DimensionalWeight', Null, array ( $unitOfMeasurement, $weight ) );
    $package->appendChild ( $dimensionalWeight );
    if ( $pkg['packageWeight'] ) {
    if ( $pkg['packageWeight']['unitOfMeasurement'] ) {
    $code = new combinedObject ( 'Code', $pkg['packageWeight']['unitOfMeasurement']['code'] );
    if ( $pkg['packageWeight']['unitOfMeasurement']['description'] ) {
    $description = new combinedObject ( 'Description', $pkg['packageWeight']['unitOfMeasurement']['description'] );
    $weight = new combinedObject ( 'Weight', $pkg['packageWeight']['weight'] );
    $packageWeight = new xmlObject ( 'PackageWeight', Null, array ( $unitOfMeasurement, $weight ) );
    $package->appendChild ( $packageWeight );
    if ( $pkg['largePackageIndicator'] ) {
    $largePackageIndicator = new combinedObject ( 'LargePackageIndicator', $pkg['largePackageIndicator'] );
    $package->appendChild ( $largePackageIndicator );
    if ( $pkg['referenceNumber'] ) {
    $code = new combinedObject ( 'Code', $pkg['referenceNumber']['code'] );
    $value = new combinedObject ( 'Value', $pkg['referenceNumber']['value'] );
    $package->appendChild ( $referenceNumber );
    if ( $pkg['packageServiceOptions'] ) {
    $packageServiceOptions = new xmlObject ( 'PackageServiceOptions' );
    if ( $pkg['packageServiceOptions']['cod'] ) {
    $monetaryValue = new combinedObject ( 'MonetaryValue', $pkg['packageServiceOptions']['cod']['codAmount']['monetaryValue'] );
    $codAmount = new xmlObject ( 'CODAmount', Null, array ( $monetaryValue ) );
    if ( $pkg['packageServiceOptions']['cod']['codAmount']['currencyCode'] ) {
    $currencyCode = new combinedObject ( 'CurrencyCode', $pkg['packageServiceOptions']['cod']['codAmount']['currencyCode'] );
    $codAmount->appendChild ( $currencyCode );
    $cod = new xmlObject ( 'COD', Null, array ( $codAmount ) );
    if ( $pkg['packageServiceOptions']['cod']['codFundsCode'] ) {
    $codFundsCode = new combinedObject ( 'CODFundsCode', $pkg['packageServiceOptions']['cod']['codFundsCode'] );
    $cod->appendChild ( $codFundsCode );
    if ( $pkg['packageServiceOptions']['cod']['codCode'] ) {
    $codCode = new combinedObject ( 'CODCode', $pkg['packageServiceOptions']['cod']['codeCode'] );
    $cod->appendChild ( $codCode );
    if ( $pkg['packageServiceOptions']['cod']['controlNumber'] ) {
    $codNumber = new combinedObject ( 'ControlNumber', $pkg['packageServiceOptions']['cod']['controlNumber'] );
    $cod->appendChild ( $controlNumber );
    $packageServiceOptions->appendChild ( $cod );
    if ( $pkg['packageServiceOptions']['deliveryConfirmation'] ) {
    $dcisType = new combinedObject ( 'DCISType', $pkg['packageServiceOptions']['deliveryConfirmation']['dcisType'] );
    $deliveryConfirmation = new xmlObject ( 'DeliveryConfirmation', Null, array ( $dcisType ) );
    $packageServiceOptions->appendChild ( $deliveryConfirmation );
    if ( $pkg['packageServiceOptions']['verbalConfirmation'] ) {
    if ( is_array ( $pkg['packageServiceOptions']['verbalConfirmation']['phoneNumber'] ) ) {
    $phoneDialPlanNumber = new combinedObject ( 'PhoneDialPlanNumber', $pkg['packageServiceOptions']['verbalConfirmation']['phoneNumber']['phoneDialPlanNumber'] );
    $phoneLineNumber = new combinedObject ( 'PhoneLineNumber', $pkg['packageServiceOptions']['verbalConfirmation']['phoneNumber']['phoneLineNumber'] );
    $phoneCountryCode = new combinedObject ( 'PhoneCountryCode', $pkg['packageServiceOptions']['verbalConfirmation']['phoneNumber']['phoneCountryCode'] );
    if ( $pkg['packageServiceOptions']['verbalConfirmation']['phoneNumber']['phoneExtension'] ) {
    $phoneExtension = new combinedObject ( 'PhoneExtension', $pkg['packageServiceOptions']['verbalConfirmation']['phoneNumber']['phoneExtension'] );
    $verbalConfirmation = new xmlObject ( 'VerbalConfirmation', Null, array ( $phoneNumber ) );
    if ( $pkg['packageServiceOptions']['verbalConfirmation']['name'] ) {
    $name = new combinedObject ( 'Name', $pkg['packageServiceOptions']['verbalConfirmation']['name'] );
    $verbalConfirmation->appendChild ( $name );
    $packageServiceOptions->appendChild ( $verbalConfirmation );
    $package->appendChild ( $packageServiceOptions );
    if ( $pkg['additionalHandling'] ) {
    $additionalHandling = new combinedObject ( 'AdditionalHandling', $pkg['additionalHandling'] );
    $package->appendChild ( $additionalHandling );
    $shipment->appendChild ( $package );
    // ShipmentServiceOptions
    if ( $shipmnt['shipmentServiceOptions'] ) {
    $shipmentServiceOptions = new xmlObject ( 'shipmentServiceOptions' );
    if ( $shipmnt['shipmentServiceOptions']['saturdayPickup'] ) {
    $saturdayPickup = new combinedObject ( 'SaturdayPickup', $shipmnt['shipmentServiceOptions']['saturdayPickup'] );
    $shipmentServiceOptions->appendChild ( $saturdayPickup );
    if ( $shipmnt['shipmentServiceOptions']['saturdayDelivery'] ) {
    $saturdayDelivery = new combinedObject ( 'SaturdayDelivery', $shipmnt['shipmentServiceOptions']['saturdayDelivery'] );
    $shipmentServiceOptions->appendChild ( $saturdayDelivery );
    if ( $shipmnt['shipmentServiceOptions']['onCallAir'] ) {
    $onCallAir = new xmlObject ( 'OnCallAir' );
    if ( $shipmnt['shipmentServiceOptions']['onCallAir']['schedule'] ) {
    $schedule = new xmlObject ( 'Schedule' );
    if ( $shipmnt['shipmentServiceOptions']['onCallAir']['schedule']['pickupDay'] ) {
    $pickupDay = new combinedObject ( 'PickupDay', $shipmnt['shipmentServiceOptions']['onCallAir']['schedule']['pickupDay'] );
    $schedule->appendChild ( $pickupDay );
    if ( $shipmnt['shipmentServiceOptions']['onCallAir']['schedule']['method'] ) {
    $method = new combinedObject ( 'Method', $shipmnt['shipmentServiceOptions']['onCallAir']['schedule']['method'] );
    $schedule->appendChild ( $method );
    $onCallAir->appendChild ( $schedule );
    $shipmentServiceOptions->appendChild ( $onCallAir );
    if ( $shipmnt['shipmentServiceOptions']['cod'] ) {
    $monetaryValue = new combinedObject ( 'MonetaryValue', $shipmnt['shipmentServiceOptions']['cod']['codAmount']['monetaryValue'] );
    if ( $shipmnt['shipmentServiceOptions']['cod']['codAmount']['currencyCode'] ) {
    $currencyCode = new combinedObject ( 'CurrencyCode', $shipmnt['shipmentServiceOptions']['cod']['codAmount']['currencyCode'] );
    if ( $shipmnt['shipmentServiceOptions']['cod']['codFundsCode'] ) {
    $codFundsCode = new combinedObject ( 'CODFundsCode', $shipmnt['shipmentServiceOptions']['cod']['codFundsCode'] );
    if ( $shipmnt['shipmentServiceOptions']['cod']['codCode'] ) {
    $codCode = new combinedObject ( 'CODCode', $shipmnt['shipmentServiceOptions']['cod']['codeCode'] );
    if ( $shipmnt['shipmentServiceOptions']['cod']['controlNumber'] ) {
    $codNumber = new combinedObject ( 'ControlNumber', $shipmnt['shipmentServiceOptions']['cod']['controlNumber'] );
    $shipmentServiceOptions->appendChild ( $cod );
    $shipment->appendChild ( $shipmentServiceOptions );
    // RateInformation
    if ( $shipmnt['rateInformation'] ) {
    $rateInformation = new xmlObject ( 'RateInformation' );
    if ( $shipmnt['rateInformation']['negotiatedRatesIndicator'] ) {
    $negotiatedRatesIndicator = new combinedObject ( 'NegotiatedRatesIndicator', $shipmnt['rateInformation']['negotiatedRatesIndicator'] );
    $rateInformation->appendChild ( $negotiatedRatesIndicator );
    $shipment->appendChild ( $rateInformation );
    /*** RatingServiceSelectionRequest ***/
    $this->xmlObject ( 'RatingServiceSelectionRequest', Null, array ( $request, $pickupType, $shipment ) );
    // CustomerClassification
    if ( $cClass['code'] ) {
    $code = new combinedObject ( 'Code', $cClass['code'] );
    $customerClassification = new xmlObject ( 'CustomerClassification', Null, array ( $code ) );
    $this->appendChild ( $customerClassification );
    Sep 2007
    You can get the tar.gz zip for UPS Heavy freight
    at this link, same as above one file,
    http://linux.softpedia.com/get/Inter...ce-33044.shtml
    Sep 2007
    We start with:
    /public_html/includes/languages/english/modules/shipping/upsfreight.php
    This is an assumption that UPS /modules/shipping/upsfreight.php
    is the same as FedEX, and Con Way Heavy Freight.
    If this assumption is true is this correct for Zen Cart,
    This module is for use with UPS's heavy freight shipping service,
    weight over 150lbs.,
    not with their regular ground shipping service.
    Released under the GNU General Public License
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_TITLE', 'UPS Freight');
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_DESCRIPTION', 'UPS Freight
    transports items over 150lbs, for items under 150lbs. use UPS Ground');
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_UPS', 'UPS Freight');
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_ERROR_BAD_COUNTRY', 'UPS, Freight is only available to customer in the United States and Canada.
    <br /> all others call or email for Freight quote, see Contact Us.');
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_ERROR_BAD_RESPONSE', 'UPS Freight returned an error or invalid response.');
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_ERROR_DESCRIPTION', 'We\'re sorry, but an error occurred while calculating the UPS Freight shipping prices.');
    define('MODULE_SHIPPING_UPSFREIGHT_TEXT_ERROR_SHIPPING_WITHIN_CA', 'We\'re sorry, but UPS Freight\'s estimator does not currently support estimates for shipping from one Canadian address to another.');
    Sep 2007
    For
    The Overrides link
    YOUR_TEMPLATE_NAME/upsfreight.php
    If you do not wish to have your UPS Module lost in upgrade,
    put this file in the Overrides Directory for this file.
    My Template is zencart_ zen so for me it would be.
    zencart_zen/upsfreight.php
    --How to do it
    Create an empty Directory,
    in my case called zencart_ zen upload to Server,
    upload upsfreight.php file in to this Directory, in the server.
    Sep 2007
    For
    The Overrides link
    --How to do it
    This is for info. only.
  1. v151 UPS Shipping module - Tweak to show UPS Freight LTL
    By pexter in forum Addon Shipping Modules
    Last Post: 13 Jun 2013, 09:37 PM
  2. Con-Way Heavy Freight Custom Module
    By Relentless in forum Addon Shipping Modules
    Last Post: 15 Mar 2011, 11:52 PM
  3. FedEx Xml Heavy Freight Module
    Last Post: 15 Sep 2010, 02:34 PM
  4. Using Fedex Freight and UPS?
    By sham in forum Addon Shipping Modules
    Last Post: 2 May 2010, 03:02 PM
  5. Way to choose Freight or UPS/FedEx
    By calvinmcdaniel in forum Setting Up Categories, Products, Attributes
    Last Post: 3 Mar 2010, 02:09 AM
