    May 2006
    Default Can someone help me with these small problems
    I'm putting together a store and I've encountered a few small things that have me completely stumped. Can someone suggest fixes.
    The first is a screenshot of the page in IE7.
    I've indicated the problems with red arrows.
    The second is a screenshot of the page in Safari 3.1
    Which has the added problem that the contents of the page overrun the main container.
    In Firefox, only Problem1 is an issue.
    Default Re: Can someone help me with these small problems
    Without a link can only speculate that this is a broken link to an image
    Overrun most likely the image is too wide for the space available
    May 2006
    Ok, here's a link. We haven't gone live yet.
    http://69.89.31.203/~sugargig/sugarcart/
    I looked through the source and I didn't see where there is an image at that location. But I may have missed something
    The overrun problem doesn't occur in Firefox or IE7 or even Konqueror. I've only seen it on Safari for Windows. So I'm assuming its a Safari problem.
    In your header the left image is 211px high and the right image is 155px high.
    You have transgressed outside of the default schema for your header with tables and these are not contained where they should be
    But you have left the logo div entry
    <div id="logo"><a href="http://69.89.31.203/~sugargig/sugarcart/"><img src="includes/templates/CUSTOM/images/" alt="" /></a></div>
    May 2006
    They are in a table the first image is in a cell that spans 2 rows. This isn't a problem.
    This again is by design. I was following what was done in
    http://www.zen-cart.com/forum/showthread.php?p=515370
    Right, there was an image tag in the empty logo div that was giving the empty image problem. I commented out the entire logo wrapper and that problem went away. Thanks.
    I'm left with the weird block at the right edge of the navigation bar.
    May 2006
    Fixed the weird block problem.
    I had search turned off in the nav bar, but the div was still there. I commented out the line
    <div id="navMainSearch"><?php require(DIR_WS_MODULES . 'sideboxes/search_header.php'); ?></div>
    and the little block went away.
  1. Can someone tell me how to do these 3 things?
    By Dave19 in forum Templates, Stylesheets, Page Layout
    Last Post: 6 Oct 2009, 05:30 PM
  2. can someone help please -- Problems with PDF Order Center
    By londoner1988 in forum All Other Contributions/Addons
    Last Post: 4 Mar 2008, 03:45 AM
  3. Can you help with these error messages?
    By Twohogwild in forum Installing on a Linux/Unix Server
    Last Post: 6 Jan 2007, 07:29 PM
