Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    Nov 2007
    Default Problem with databse transfer oscommerce to zencart
    I am moving a database from OScommerce to Zencart.
    I have moved all the categories OK.
    I have moved all the product structure OK.
    BUT when I try to import the products I get the following error message:
    Error
    SQL query:
    -- Database: `mydatabase_name`
    -- Dumping data for table `products`
    INSERT INTO `products`
    VALUES ( 1, 33, '228', 'products/1.jpg', 'products/1.jpg', 'products/1.jpg', '', '', '', '', '', '', '', '', '', '', '', '', 2.8500, NULL , '2007-12-20 23:08:16', NULL , 1.00, 1, 0, NULL , 1, 0, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0.0000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 'G,0', 7, '', '', '', '', 0.00, 2288, 2.85, '0' ) ;
    MySQL said:
    #1136 - Column count doesn't match value count at row 1
    Apr 2006
    London, UK
    Default Re: Problem with databse transfer oscommerce to zencart
    This is telling you that osCommerce and Zen Cart don't have the same table structure for products.
    One or both may have extra fields added since they split, and the osCommerce from which you are transferring may have mods that have added extra fields.
    Have you compared the products tables in both to see what differences there are?
    Nov 2007
    I have already added all tables into zencart that existed in the oscommerce database. There are now more tables in the zencart than in the oscommerce.
    Apr 2006
    London, UK
    The issue isn't about adding tables, it's that the products table in Zen Cart appears to be a different shape to that for the osCommerce database from which you are converting.
    This is getting highlighted because you have adopted a high risk approach to conversion, namely dumping each osCommerce row into a Zen Cart row in the hope that the fields will match, rather than mapping the fields so that you know that data is being taken from osCommerce and placed into the right field in Zen Cart.
    Nov 2007
    Do you have any suggestions how I can rectify this and get all the products imported?
    Apr 2006
    London, UK
    Since the tables appear to have different structures, assign the data from one to the other using column names that you have mapped between them, rather than by inserting a list of values. If Zen Cart has more column names you may need to assign default values to the new columns.
    Nov 2007
    Would you be willing to sort this out for me if I paid you?
    Apr 2006
    London, UK
    I have a partner who is especially skilled in this type of conversion, and she has contacted you separately. But we would recommend that you take a look at this mod first (sorry all documentation is in French, but it's pretty easy to use even if you don't understand the docs).
    Feb 2008
    Orange County, CA
    I have released a new OSC - Zen data importer.
    New and improved for multi-step migrations and easy to use.
    If you still need it, that will solve most of your problems.
    Albert
    http://www.zen-cart.com/index.php?ma...roducts_id=918
    Oct 2006
    I know many people would love this, thanks alot for the great contribution.
    Quote Originally Posted by albertsavage View Post
    Albert
    I no longer provide installation support on forum for all my modules. However, if there are real bugs with the modules please feel free to contact me
  1. OSCommerce to Zen Cart Data Transfer add-on problem
    By Stevis2002 in forum All Other Contributions/Addons
    Last Post: 14 Oct 2010, 01:03 PM
  2. Stay with OsCommerce or go back to zencart
    By Ch4iS in forum General Questions
    Last Post: 20 Aug 2009, 11:54 AM
  3. merging oscommerce with zencart???
    By 1kell in forum General Questions
    Last Post: 14 Jul 2008, 01:06 PM
  4. Using oScommerce contributions with ZenCart
    By DiZZ in forum General Questions
    Last Post: 11 Nov 2006, 06:11 AM
