Results 11 to 20 of 29
    Mar 2008
    Default Re: CSS problems - Stylesheet won't load
    Does your hosting account give you access to the server errorlogs for your site?
    If so, check what messages are in the errorlog. Any 403 errors should be listed there. Hopefully there is also a "reason" listed with the error message.
    If you can't see the logs yourself, contact your hosting company for access or get them to give you a copy of the errorlogs from the last 24 hours etc.
    Here is what the errors all say:
    denied: /home/8190/domains/modern-contemporaryfurniture.com/html/includes/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable, referer: http://modern-contemporaryfurniture.com/
    [Fri Apr 04 08:57:37 2008] [crit] [client 12.41.116.10] (13)Permission denied: /home/8190/domains/modern-contemporaryfurniture.com/html/includes/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable, referer: http://modern-contemporaryfurniture.com/
    I checked the folders all the way down and there are no other .htaccess files.
    So I changed my .htaccess file back to .htaccess from .htaccess_off and the same error is provided when the .htaccess file is renamed either way.
    What are the permissions on the /includes/.htaccess file?
    Mar 2008
    the permission is 644
    That would seem normal.
    But, you said this all started happening around the time you were altering your configure.php and changing permissions, right?
    Perhaps you've accidentally changed something else related to permissions.
    Now, something that's puzzling ...
    You said you renamed /includes/.htaccess to htaccess_off
    When you did that, and then checked the server errorlogs, do you keep getting new permissions errors about /includes/.htaccess ?
    You shouldn't.
    So ... what happens if you delete the /includes/.htaccess file altogether? Don't rename it. Just delete it. That gets rid of the permissions issue which would follow the file when you rename it.
    Mar 2008
    You shouldn't.
    Yes, that same error persisted after renaming and naming back checked many times to make sure.
    I have now deleted the includes/.htaccess and no changes
    Quote Originally Posted by johnbtes View Post
    So, after deleting the file, are the errorlogs *still* logging *new* permission errors?
  7. #17
    Mar 2008
    Yes it is still logging new errors stating:
    [Fri Apr 04 10:47:41 2008] [crit] [client 12.41.116.10] (13)Permission denied: /home/8190/domains/modern-contemporaryfurniture.com/html/includes/.htaccess pcfg_openfile: unable to check htaccess file, ensure it is readable, referer: http://modern-contemporaryfurniture.com/
    I go and refresh the webpage http://modern-contemporaryfurniture.com and then go back to my errorlog and there are new logs stating that same error.
  8. #18
    ... and you're sure that you've been working with the correct .htaccess file?
    ie: /home/8190/domains/modern-contemporaryfurniture.com/html/includes/.htaccess
    Sounds like you need to talk to your hosting company for specific help.
  9. #19
    Mar 2008
    Does this make sense though? For the .htaccess to be affecting the permission of the stylesheets?
    When I went to change the template in the Admin to classic and I just clicked preview it threw a 403 because of the preview image.
    If I just edited and changed the theme I didn't get the 403, just an error talking about my meta tags module.
    I'm not sure why the .htaccess would be doing this?
  10. #20
    Mar 2008
    Here is a screenshot.
    If it would help I could send full page screenshots to you showing you any area you would like to see.
  1. Site won't load CSS until reload
    By smm11 in forum General Questions
    Last Post: 26 Jan 2012, 09:34 PM
  2. CSS styles won't load after installing
    By jaycode in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Jun 2007, 01:18 PM
  3. Replies: 39
    Last Post: 5 Jun 2007, 06:42 AM
