i am doin same as it is said in all the help units
but then also i m not able to make out that effect, even goin into the imagehandler panel makin 3 types of pixels/size of a image
plz help me
payal
plz help me
payal
hi
its the effct when we take the cursor on that pic it shows us the preview without clickin on it
its damn cool effct and very common
thxs
It may have something to do with your IMAGE SIZE settings. ((Admin...Images).
I believe IH2 is very fussy with the "HOVER" effect, and requires the settings to be exactly:-
... Oh, and the ZOOM SIZE is determined by your size setting for the image that appears on your Product Info pages...
...So the zoomed hover image is the same size as the image that appears on the Product Info pages.
no no no
i m not able to get
i m sending u my website link plz check..
i have made all settings of images as u told to do!
plz check thxs
i can't see the zoom effect damn damn
In order for someone to really help you with this, you'd have to give him/her access to your Zen Cart admin.
IH2 doesn't require copies of the same image in different sizes. You need only one copy in the largest size required. IH2 will do the resizing for the other sizes required.
Do you have the zoom turned on in admin->configuration->images?
yea i have given access to fairestcape
but how did u do it
i need to know in order to implemend in other zencarts
thxs so much
i ll be waitin for ur reponse fairestcape
