itssssssssssssssssss workin on classic template and not on others
why is that![]()
why is that![]()
was askin fairestcape, he has made the effect right but it does not come to other templates of mine
afo i think u r also using the classic template
thats y theres no prob
i don't know when i m changing to other custom templates
the effect is not cmin
i need to ask fairestcape
but wht do u think why its not showin in the other templates?
the files are there...
Afo... payal gave me admin access, so I don't know what's in the php for his templates, but I could not get IH2 to work with any of his custom templates. I pointed out that some of IH2's php files need to be in the over-rides directories of the chosen template, and looking above, that seems to be the case.
I cleaned things up a bit (he was using gifs in some cases which don't work with IH2 and some of the jpg's had very peculiar names - eg: microsoft/special/wertr_iio.jpg... yes, the name included the slashes!)
On his installation, IH2 would ONLY work if I reverted to Classic Green, and uploaded my own test products with my own test images (suggesting that payal had correctly installed IH2 for this template).
But as he says he's also correctly installed it for the other template, I can only suppose there's an incompatibility there (and as I don't have access to the php, I can't be sure...)
ok i m closing the topic as i have successfully installed the ih2
u guys were right
there was a problem in over all dummy installation as i have installed many modules and templates as trial
thanks alot
i m sending you both the main website
thanks again
payal
