Results 1 to 10 of 10
    Aug 2007
    Brighton, UK
    Default Having problems with rates.
    My goal is to have £6.50 shipping cost up to £75, above £75 i would like the shipping cost to be free. Unfortunatly it is not working the way i would like. I have provided screen shots to show you what i have done.
    ---------The options i have selected screen shots---------------------
    http://www.freewebs.com/test-temp/Shipping.JPG
    ---------Estimated shipping screenshots--------------------------------
    */I would like this to show that it will be £6.50 on order under £75, at the moment there is no information on this page to show this (this is the main problem i am having)./*
    http://www.freewebs.com/test-temp/shipping2.JPG
    Any help greatly appreciated
    Elliot
    Jan 2008
    Default Re: Having problems with rates.
    In your Table Rate, why not put 75:6.50,10000:0
    (Also ensure Calculation Method is set to Price)
    Then get includes\languages\english\modules\shipping\table.php
    Put a copy of it into your custom folder, then edit the relevant constants.
    Aug 2007
    Brighton, UK
    Thanks, i still cant get it to say that it will cost 6.50 in the estimated shipping. Could u expand on what i shuld edit the table.php to?
    Many thanks
    Elliot
    Jan 2008
    Quote Originally Posted by Orchard_Direct View Post
    Well with the Table Rate installed, you would normally get a line on the Shipping Estimator saying "Table Rate (Best Way)", with the price over to the right. Modifying the file I suggested allows you to edit the part that says "Table Rate (Best Way)" to something else.. maybe something that reflects your free shipping deal.
    Ok so nothing appears in your Estimator table? Have you made any customisations to the files? Or it might be a template issue, try switching to the classic template.
    Aug 2007
    Brighton, UK
    Have made no customizations and nothing appears when using classic template either, it is exactly the same as shown in template 2.
    Aug 2007
    Brighton, UK
    Lol this is doing my head in!
    Jan 2008
    It looks as if you've made a lot of changes in admin regarding your shipping setup. Maybe some of the settings conflict with each other. I would try resetting everything to defaults. Then try again with just the Table Rate. Other than that, I'm afraid I can't suggest anything else.
    Aug 2007
    Brighton, UK
    Is there a quick way to change shipping modules to default? cheers.
    Jan 2008
    Removing and re-installing each module should reset their values. Just remember to write down any settings which you plan on using again.
    Also, if you're not sure what admin defaults are, I find this site often comes in useful, it allows you to browse the admin side of a fresh install.
    Feb 2007
    if your zones and contries and tax is all correct then the table rate is the way forward and should work in seconds
  1. Having problems with easyslider
    By WitchysHeart in forum All Other Contributions/Addons
    Last Post: 30 Apr 2012, 03:40 AM
  2. Having Problems With Attributes
    By xtreme101 in forum General Questions
    Last Post: 3 Dec 2008, 02:49 PM
  3. Having problems with product image?
    By PetesTown in forum Templates, Stylesheets, Page Layout
    Last Post: 26 Jul 2007, 10:00 PM
  4. having problems with payment setup
    By ineyard in forum Built-in Shipping and Payment Modules
    Last Post: 19 Jan 2007, 05:49 AM
  5. I am having problems with login
    By ryanwhite36 in forum General Questions
    Last Post: 17 Sep 2006, 11:46 PM
