I ve put 2 links in this banner box but they dont show up together only in a rotation depending on refresh. How can i change it so they are in there together using the banner manager???
Regards
Luke
Regards
Luke
Thats a good question Luke I was comeing on to ask the same question. Not about sponsor banner but in general . I'm trying to add a military,fire,and police discount banner to my site but have found no way to keep the banner from going on rotation?
Use the Banners-All banners group to put more than one banner in a box.
Give each one a sort order for your display preference.
Banner tutorial here:
https://www.zen-cart.com/tutorials/index.php?article=80
I'm using Banners-All but I need to have an other bloc with multiple banners on it for another purpose. How can I do that?
nope no dice i did what the tutorial said changed all my banners to bannersall then chagned the layout settings and the sponsors box didnt even show up so i chagned it back and it just did the one link rotation thoughts besides the fact im mental.
Also would it be easier to just use ez pages my understanding is u can just put all ur links on them not that i know how to do that even tho ive been readin and trailin to do it
Maybe, but I would like to manage it from the banner manager.
I partially found the solution... but I do not recommend to try it since you know what your doing, because sincerely, I'm not! I'm just trying some things I found logical but I don't know much about PHP and how it works. But for you information, of if you think you can help me, here's what I did.
I duplicated the banner_box_all.php located in includes/modules/sideboxs and renamed the copy banner_box_all2.php. I did the same with tpl_banner_box_all.php located in includes/templates/MYTEMPLATE. I also worked in these files to change the names by adding "2" at the end of each related words. (sorry, I don't know how to explain that in english).
Anyway, here are the the files:
banner_box_all2.php
PHP Code:<?php
* banner_box_all2 sidebox - used to display "square" banners in sideboxes
* @package templateSystem
* @version $Id: banner_box_all.php 3133 2006-03-07 23:39:02Z ajeh $
// INSERT INTO configuration (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) VALUES ('Banner Display Group - Side Box banner_box_all2', 'SHOW_BANNERS_GROUP_SET_ALL2', 'BannersAll2', 'The Banner Display Group may only be from one (1) Banner Group for the Banner All 2 sidebox<br /><br />Default Group is BannersAll2<br /><br />What Banner Group do you want to use in the Side Box - banner_box_all2?<br />Leave blank for none', '19', '72', '', '', now());
// ALTER TABLE `banners` ADD `banners_sort_order` INT( 11 ) DEFAULT '0' NOT NULL;
// test if box should display
$show_banner_box_all2 = true;
if (SHOW_BANNERS_GROUP_SET_ALL2 == '') {
$show_banner_box_all2 = false;
if ($show_banner_box_all2 == true) {
$banner_box[] = TEXT_BANNER_BOX_ALL2;
$banner_box_group= SHOW_BANNERS_GROUP_SET_ALL2;
require($template->get_template_dir('tpl_banner_box_all2.php',DIR_WS_TEMPLATE, $current_page_base,'sideboxes'). '/tpl_banner_box_all2.php');
// if no active banner in the specified banner group then the box will not show
// uses banners in the defined group $banner_box_group
if ($banners_all->RecordCount() > 0) {
$title = BOX_HEADING_BANNER_BOX_ALL2;
$title_link = false;
require($template->get_template_dir($column_box_default, DIR_WS_TEMPLATE, $current_page_base,'common') . '/' . $column_box_default);
I then looked in the Layout Box Controller and banner_box_all2,php was now there! Cool! But it wasn't in the configuration/layer setting, so I run the following statement as an SQL patch:PHP Code:<?php
* Side Box Template
* @version $Id: tpl_banner_box_all2.php 2982 2006-02-07 07:56:41Z birdbrain $
$content = '';
$content .= '<div id="' . str_replace('_', '-', $box_id . 'Content') . '" class="sideBoxContent centeredContent">';
// select banners_group to be used
$new_banner_search = zen_build_banners_group(SHOW_BANNERS_GROUP_SET_ALL2);
// secure pages
switch ($request_type) {
case ('SSL'):
$my_banner_filter=" and banners_on_ssl= " . "1 ";
case ('NONSSL'):
$my_banner_filter='';
$sql = "select banners_id from " . TABLE_BANNERS . " where status = 1 " . $new_banner_search . $my_banner_filter . " order by banners_sort_order";
$banners_all = $db->Execute($sql);
$banner_cnt = 0;
while (!$banners_all2->EOF) {
$banner_cnt++;
$banner = zen_banner_exists('dynamic', SHOW_BANNERS_GROUP_SET_ALL2);
$content .= zen_display_banner('static', $banners_all2->fields['banners_id']);
// add spacing between banners
if ($banner_cnt < $banners_all2->RecordCount()) {
$content .= '<br /><br />';
$banners_all2->MoveNext();
$content .= '</div>';
It then appeared in the Layout Setting. Now I have a bug... When I make banner_box_all2.php active in the Controller it makes some other side boxes dissapear. So it needs a little more to work properly. And since I'm just playing with that, I'm not really sure to know what to do. I'm also note really sure of what I did... lolPHP Code:INSERT INTO configuration (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) VALUES ('Banner Display Group - Side Box banner_box_all2', 'SHOW_BANNERS_GROUP_SET_ALL2', 'BannersAll2', 'The Banner Display Group may only be from one (1) Banner Group for the Banner All 2 sidebox<br /><br />Default Group is BannersAll2<br /><br />What Banner Group do you want to use in the Side Box - banner_box_all2?<br />Leave blank for none', '19', '72', '', '', now());
Ok, I make it worked! So ignore the previous post, it has made a little mistakes in each files I modified. So here's how to do it. It worked for me, you can try it on your own risk if you want. Only 2 files to add and a patch to run. Do not forget to backup your database before if you want to do it. I'm not responsible for any problem you can have.
1- Create this file is and name it "banner_box_all2.php" :
2- Change the linePHP Code:<?php
* @version $Id: banner_box_all2.php 3133 2006-03-07 23:39:02Z ajeh $
if ($banners_all2->RecordCount() > 0) {
$title = 'Title of your sidebox';
?>by replacing 'Title of your sidebox' by, guess what, the name of your sidebox.PHP Code:$title = 'Title of your sidebox';
3- Upload it in : includes/modules/sideboxes/
4- Create this file is and name it "tpl_banner_box_all2.php" :
5- Upload it in : includes/templates/sideboxes/YOUR_TEMPLATES/sideboxes/PHP Code:<?php
* Side Box Template
$content = '';
// secure pages
case ('SSL'):
case ('NONSSL'):
$banners_all2 = $db->Execute($sql);
$banner_cnt = 0;
$banner_cnt++;
6 - Run the following SQL patch in the your admin/tools/install SQL Patches :
That's it. It worked for me.PHP Code:INSERT INTO configuration (configuration_title, configuration_key, configuration_value, configuration_description, configuration_group_id, sort_order, use_function, set_function, date_added) VALUES ('Banner Display Group - Side Box banner_box_all2', 'SHOW_BANNERS_GROUP_SET_ALL2', 'BannersAll2', 'The Banner Display Group may only be from one (1) Banner Group for the Banner All 2 sidebox<br /><br />Default Group is BannersAll2<br /><br />What Banner Group do you want to use in the Side Box - banner_box_all2?<br />Leave blank for none', '19', '72', '', '', now());
Feel free to make any correction if you think it is necessary!
nah to be honest im turd at php and even if i could find tht stuff i wouldn fool with it but ur help is much obliged.
