Results 1 to 10 of 11
    Mar 2007
    AZ
    Default Problems with FTP images
    My FTP freezes, chokes, then dies whenever I try to transfer image files! I have to task manager end the session to close the FTP.
    At first I thought I had a virus/malware - did all the checks - nothing.
    I installed a different FTP program and the problem persists.
    Could this be a problem with a .htacess somewhere?
    I beleive that I hotlink protected my images after reading a post by someone who had his images "borrowed" and used on someone else's website - could this be the problem?
    IF this makes any sense to anyone, please help. I'm going nuts here trying to get to the bottom of this issue.
    Default Re: Problems with FTP images
    How large in bytes are the images you are uploading?
    On the hotlink protection - On both sites in your sig I can grab the images without an issue and really trying to protect from this is futile if on the www
    Mar 2007
    AZ
    Some of the files are very small (49 bytes) others are larger (14.8 kb).
    When I double click the "images" folder to open it - the ftp freezes.
    This only happen with images - any other file type I open and transfer is fine!
    This issue makes it hard to add some of the great mods that area available from the download section. (Even just a trying to add a new template has issues!)
    Jun 2003
    Are you having the same problem on other hosts?
    If your problem happens when you're attempting to view the contents of your /images folder, then if you've got thousands of files in that folder, it's not surprising that you may have FTP problems, since it has to enumerate all those files and display their details to you. It's a common problem with FTP and folders with very large numbers of files in them.
    In that situation, you can still drag-and-drop images "into" the folder, but opening the folder to view its contents can be problematic.
    The workaround to access those files is often to use your hosting company's control panel's file manager tool instead.
    Mar 2007
    AZ
    Yes -different hosts, same issue!
    I have the problem even if the folder contains only 3 images (like in the Testimonials Manager download).
    I have noticed that the icon for the image sometimes changes to a hand! What's that about????
    Attachment 3947
    What FTP clients do you have - Are using?
    Mar 2007
    AZ
    I have FlashFXP - registered copy and I just installed FileZilla.
    Any better Luck with Filezilla?
    Mar 2007
    AZ
    Same issue.
  1. v153 Problems with Attribute Images
    By arthena in forum Setting Up Categories, Products, Attributes
    Last Post: 25 Jul 2014, 09:18 AM
  2. adding multiple images (need help with FTP)
    By fetishesrus in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Aug 2009, 01:39 PM
  3. FTP problems
    By Mortenjan in forum General Questions
    Last Post: 23 Jun 2008, 11:42 PM
