Results 1 to 10 of 13
    May 2008
    Default Add category name in Greek language problem
    Hi everyone,
    I have the cart running and everything so far works fine in demo. Now I have started adding categories using the Greek language. Nevertheless some items are accepted in Greek but then others are rejected.
    You can see it here: http://www.cubebookstores.gr/shop/in...index&cPath=69
    There you will see that it has a subcategory called "Λογοτ&#" instead of "Λογοτεχνία"
    Version 1.3.8
    Probably it is something silly but any idea/help/hint will be appreciated.
    Tassos
    May 2008
    Default Problem with Greek pack
    I have installed the greek pack but when I try to enter categories some letters are not accepted. Any ideas?
    For example a category displays as Λογοτ&# instead of Λογοτεχνία . This is strange as I can enter the same phrase in the description without any problem. You can see it here:
    http://www.cubebookstores.gr/shop/in...ex&cPath=69_70
    I am using v1.3.8
    Any ideas will be appreciated.
    Tassos
    Nov 2007
    USA
    Default Re: Problem with Greek pack
    Tassos:
    I am constantly checking for new versions so this is it. I am going to attempt to get this right. All previous contributions did not work.
    Try
    iso-8859-7
    You are using
    iso-8859-1
    Cheers!
    v2.2.1
    May 2005
    Sorry for bumping the thread, but I have the very same problem.
    While on other (information) pages Greek letters with accent are accepted normaly, there is problem with categories.
    I use charset=iso-8859-7 - no result...
    Can someone help about this?
    Regards, Zoreli
    May 2005
    Default Re: Problem with Greek pack - Solved
    I open the database, and the length of the categories_name in the table categories_description vas (varchar 32 or 35) ...I cant recall now.
    I make it varchar (255) and it work like a charm.
    That is because Greek data for each letter in the database look like: &%ERED and all this for one letter only, so you can imagine.
    Regards, Zoreli
    Nov 2007
    USA
    Where exactly?
    Cheers!
    v2.2.1
  1. greek language pack problem
    By zoreli in forum Addon Language Packs
    Last Post: 5 Sep 2011, 08:56 AM
  2. CAPTCHA Image Problem with greek
    By xpcprocy in forum All Other Contributions/Addons
    Last Post: 16 Jun 2011, 10:36 AM
  3. Greek language pack on version 1.3.8a
    By Phoebus in forum Addon Language Packs
    Last Post: 13 Oct 2010, 03:38 PM
  4. Good news for greek language pack on version 1.3.8
    By vasilios in forum Addon Language Packs
    Last Post: 16 Jan 2010, 08:10 AM
  5. Charset problem with Greek
    By Asdesign in forum Addon Language Packs
    Last Post: 12 Dec 2009, 05:34 PM
