You will need to understand/apply Zen Cart's Template Overrides system in order to edit the relevant files to suit your design needs. You should also be familiar with Admin settings that control the look of your store. (e.g. side-boxes, columns)
You can refer to the tutorials/FAQ for more help.
To get you started with the template overrides, here are a few quick links:
