Results 1 to 2 of 2
    Default allow ordering less than Product Qty Minimum when stock is low
    Is it possible to configure Zen Cart so a customer can still order a product if the Products Quantity (stock) drops below the Product Qty Minimum?
    If there is enough stock the Product Qty Minimum should always apply.
    I would like to allow customers to order less than the Product Qty Minimum so I can sell the remaining stock. But the customer should never be able to order more than the remaining stock.
    Daniel
    Jun 2003
    Default Re: allow ordering less than Product Qty Minimum when stock is low
    You can't have it both ways automatically. You'll have to remove your minimum when the stock reaches that level and make sure to have the stock settings so they can not checkout with more than you have.
  1. Show available stock level in cart when less than order
    By Scott Benton in forum General Questions
    Last Post: 6 Aug 2013, 04:23 AM
  2. v150 How to set default 'Product Qty Minimum' to something other than 1
    By actionjackson57 in forum Setting Up Categories, Products, Attributes
    Last Post: 28 Jan 2013, 06:50 AM
  3. v151 "Display Cart After Adding Product" - Only if Stock is Less than 1
    By gaffettape in forum General Questions
    Last Post: 6 Jan 2013, 08:40 PM
  4. Show available stock level when less than order
    By Dunk in forum General Questions
    Last Post: 10 Feb 2009, 02:39 PM
  5. Less than Min $ to allow lower minimum
    By JimCrown in forum Setting Up Categories, Products, Attributes
    Last Post: 24 Oct 2007, 12:55 AM
