Thread: Jrox problem
Results 1 to 10 of 12
    Default Jrox problem
    I tried setting up Jrox affiliate system but for some reason its not working.
    My understanding is if I add their code to /includes/languages/english/checkout_success.php it should work but when I checkout successfully I the
    Your Order Number is: 244
    Thank you for your payment. You will be notified once your order ships
    Thank you for shopping. Please click the Log Off link to ensure that your receipt and purchase information is not visible to the next person using this computer.
    info but viewing the source I get none of the data I put into the checkout_success.php file...
    Is there any reason that file wouldn't be used or am I doing something wrong?
    It looks like its using all the default information here
    What am I doing wrong?
    I have posted on their message board but with no replies yet.
    Feb 2006
    Tampa Bay, Florida
    Default Re: Jrox problem
    You shouldn't be adding code to a languages file.
    Dr Byte & I updated the documentation for this a while ago - did you read the documentation? I'm on the road and don't have it with me now.
    7
    swguy's right ... there's no reason to touch a language file for the sake of JAM integration.
    Did you follow the setup instructions on the JAM site?
    Please post the link to the instructions you followed.
    What version of Zen Cart are you using?
    I'm using 1.3.7 and the docs I used are http://jam.jrox.com/docs/index.php?article=111
    I think maybe I have the wrong custom folder, is there a way to look inside of zencart config to see what my custom folder I am using?
    Someone else set it up for me and am not sure what folder that are using.
    7
    Yes, you're clearly using the wrong folder.
    If you go back and read the instructions on the page you posted the link to, you'll see that it's talking about a "template" file named "tpl_footer.php" in a folder called "checkout_success".
    It doesn't make any reference to any files in the language folders.
    I suggest going back to it and following it step by step again.
    You can find out the name of your custom template folder by going to Admin->Tools->Template Select and see which template is currently enabled.
    Ok I see where the confusion is I mis pasted some information in my original post. I did read the instructions and did do what they said I just pasted the wrong path.
    I meant to past this as the first path
    /includes/templates/custom/common/checkout_success/tpl_footer.php
    It doesn't work there its not pulling the file at all so I tired pulling from this path as well
    /includes/templates/custom/checkout_success/tpl_footer.php
    So in total I have pasted the code into
    And neither work.
    After looking at the custom teplates my correct ones are here
    /includes/templates/custom/common/*
    It still is not pulling the correct footer...
    I did look around and tested it and its still pulling from
    /includes/templates/template_default/templates/tpl_checkout_success_default.php
    I can't seem to get it to pull the file from the custom template folder.
    ideas?
    Modifying this file I got it to work correctly
    I still can not get it to pull the correct file from either
    Not sure what one is correct but one of those locations should be?
    Since my acutal custom templates are located here
    /includes/templates/custom/common/tpl_main_page.php and so on.
    Mar 2004
    do you have an actual template named custom?
    if you look in zc admin tools template what template is turned on
    Quote Originally Posted by Merlinpa1969 View Post
    When I go tools template selection this is what shows up on the left.
    Template Language=Default(All)
    Template Name=Custom Template
    Template Directory=custom
    On the right there are 3 templates installed.
    So looks like I have it and it is the active template.
    Also making changes to any of the files here
    /includes/templates/custom/common/* makes changes to the site.
    Mar 2004
    would be correct,
    this way this tpl_footer ONLY shows on the checkout_success page
    do you have a url to look at?
  1. Jrox?
    By zulu26 in forum General Questions
    Last Post: 28 Feb 2012, 07:24 PM
  2. Jrox jam
    By johnybravo in forum All Other Contributions/Addons
    Last Post: 29 Sep 2011, 04:17 PM
  3. Installing JROX problem
    By Dawl in forum All Other Contributions/Addons
    Last Post: 7 Apr 2009, 08:04 PM
  4. JROX Anyone??
    By woofgangs in forum Installing on a Linux/Unix Server
    Last Post: 7 Dec 2007, 06:57 AM
  5. JROX question
    By AMC in forum General Questions
    Last Post: 1 Oct 2006, 09:30 PM
