Results 1 to 7 of 7
    Aug 2008
    Default Help with SSL and Admin Page Not Working
    ok i set up 2 test sites, and i get errors on one of them. INFO BELOW
    http://chuck68tx.net/zencart/admin this is the link without SSL on and i did not change anything in the files and everything works , main page and admin section........
    only thing i added was the cherry_zen template to both
    with the site without SSL on i can use all the links in the header and all the pages show.
    the site with SSL on the links for My Account and Checkout only bring up blank pages also.
    the error below is what comes up when i try to go to my admin with this link:
    http://chuck68tx.net/admin , only thing i changed was the info for setting up SSL
    i followed the instructions
    in the turtorials section on setting up SSL....... the main site for http://chuck68tx.net itself works ......
    This is the error i get with the SSL on trying to log into the Admin on http://chuck68tx.net/admin
    Warning: session_start(): Cannot send session cookie - headers already sent by (output started at /home/content/c/h/u/chuck68tx/html/admin/includes/configure.php:183) in /home/content/c/h/u/chuck68tx/html/includes/functions/sessions.php on line 108
    Warning: session_start(): Cannot send session cache limiter - headers already sent (output started at /home/content/c/h/u/chuck68tx/html/admin/includes/configure.php:183) in /home/content/c/h/u/chuck68tx/html/includes/functions/sessions.php on line 108
    Warning: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/chuck68tx/html/admin/includes/configure.php:183) in /home/content/c/h/u/chuck68tx/html/admin/includes/init_includes/init_templates.php on line 36
    Warning: Cannot modify header information - headers already sent by (output started at /home/content/c/h/u/chuck68tx/html/admin/includes/configure.php:183) in /home/content/c/h/u/chuck68tx/html/admin/includes/functions/general.php on line 21
    Admin Includes Config:
    define('HTTP_SERVER''http://chuck68tx.net');
    define('HTTPS_SERVER''https://chuck68tx.net');
    define('HTTP_CATALOG_SERVER''http://chuck68tx.net');
    define('HTTPS_CATALOG_SERVER''https://chuck68tx.net');
    // secure webserver for catalog module and/or admin areas?
    define('ENABLE_SSL_CATALOG'' true' );
    define('ENABLE_SSL_ADMIN'' false' );
    // * DIR_WS_* = Webserver directories (virtual/URL)
      // these paths are relative to top of your webspace ... (ie: under the public_html or httpdocs folder)
    define('DIR_WS_ADMIN''/admin/');
    define('DIR_WS_CATALOG''/');
    define('DIR_WS_HTTPS_ADMIN''/admin/');
    define('DIR_WS_HTTPS_CATALOG''/');
    Includes Config:
    // Define the webserver and path parameters
    // HTTP_SERVER is your Main webserver: eg-http://www.yourdomain.com
    // HTTPS_SERVER is your Secure webserver: eg-https://www.yourdomain.com
    // Use secure webserver for checkout procedure?
    define('ENABLE_SSL'' true' );
    define('DIR_WS_IMAGES''images/');
    define('DIR_WS_INCLUDES''includes/');
    define('DIR_WS_FUNCTIONS'DIR_WS_INCLUDES 'functions/');
    define('DIR_WS_CLASSES'DIR_WS_INCLUDES 'classes/');
    define('DIR_WS_MODULES'DIR_WS_INCLUDES 'modules/');
    define('DIR_WS_LANGUAGES'DIR_WS_INCLUDES 'languages/');
    define('DIR_WS_DOWNLOAD_PUBLIC'DIR_WS_CATALOG 'pub/');
    not sure why i get the problems with SSL on
    Chuck68tx
    7
    Default Re: Help with SSL and Admin Page Not Working
    1. Why do you have spaces inside the ' true' and ' false' values for your SSL settings?
    2. Why are your files double-spaced?
    3. Since the error message is telling you there's a problem on line 183 of your admin configure.php file, what's on line 183 ?
    http://tutorials.zen-cart.com/index.php?article=87
    Aug 2008
    this is the info where line 183 is: i have tried all 3 methods it says and tried both permission settings and still get the same errors. oh and not sure why there are spaces inside the true and false i fixed that.
    // The next 2 "defines" are for SQL cache support.
      // For SQL_CACHE_METHOD, you can select from:  none, database, or file
      // If you choose "file", then you need to set the DIR_FS_SQL_CACHE to a directory where your apache
      // or webserver user has write privileges (chmod 666 or 777). We recommend using the "cache" folder inside the Zen Cart folder
      // ie: /path/to/your/webspace/public_html/zen/cache   -- leave no trailing slash
    define('SQL_CACHE_METHOD''none');
    define('DIR_FS_SQL_CACHE''/home/content/c/h/u/chuck68tx/html/cache');
    7
    What's on lines 175-thru-185 ?
    (change your password to xxxxxx when posting, if that's on one of those lines)
    Aug 2008
    Ok i deleted out my server info before i posted this. this is my whole admin/includes/configure.php file. thought it might be easier to post the whole thing . there are no passwords showing i took them out.
     * dist-configure.php
     * @package Configuration Settings
     * @package Admin
     * @copyright Copyright 2003-2007 Zen Cart Development Team
     * @copyright Portions Copyright 2003 osCommerce
     * @license [url]http://www.zen-cart.com/license/2_0.txt[/url] GNU Public License V2.0
     * @version $Id: dist-configure.php 6329 2007-05-16 15:36:56Z drbyte $
     * @private
    // HTTP_CATALOG_SERVER is your Main webserver: eg-http://www.yourdomain.com
    // HTTPS_CATALOG_SERVER is your Secure webserver: eg-https://www.yourdomain.com
     * URL's for your site will be built via:
     *     HTTP_SERVER plus DIR_WS_ADMIN or
     *     HTTPS_SERVER plus DIR_WS_HTTPS_ADMIN or
     *     HTTP_SERVER plus DIR_WS_CATALOG or
     *     HTTPS_SERVER plus DIR_WS_HTTPS_CATALOG
     * ...depending on your system configuration settings
     * If you desire your *entire* admin to be SSL-protected, make sure you use a "https:" URL for all 4 of the following:
    define('ENABLE_SSL_CATALOG''true');
    define('ENABLE_SSL_ADMIN''true');
    // NOTE: be sure to leave the trailing '/' at the end of these lines if you make changes!
    define('DIR_WS_ICONS'DIR_WS_IMAGES 'icons/');
    define('DIR_WS_CATALOG_IMAGES'HTTP_CATALOG_SERVER DIR_WS_CATALOG 'images/');
    define('DIR_WS_CATALOG_TEMPLATE'HTTP_CATALOG_SERVER DIR_WS_CATALOG 'includes/templates/');
    define('DIR_WS_BOXES'DIR_WS_INCLUDES 'boxes/');
    define('DIR_WS_CATALOG_LANGUAGES'HTTP_CATALOG_SERVER DIR_WS_CATALOG 'includes/languages/');
    // * DIR_FS_* = Filesystem directories (local/physical)
      //the following path is a COMPLETE path to your Zen Cart files. eg: /var/www/vhost/accountname/public_html/store/
    define('DIR_FS_ADMIN''/home/content/c/h/u/chuck68tx/html/admin/');
    define('DIR_FS_CATALOG''/home/content/c/h/u/chuck68tx/html/');
    define('DIR_FS_CATALOG_LANGUAGES'DIR_FS_CATALOG 'includes/languages/');
    define('DIR_FS_CATALOG_IMAGES'DIR_FS_CATALOG 'images/');
    define('DIR_FS_CATALOG_MODULES'DIR_FS_CATALOG 'includes/modules/');
    define('DIR_FS_CATALOG_TEMPLATES'DIR_FS_CATALOG 'includes/templates/');
    define('DIR_FS_BACKUP'DIR_FS_ADMIN 'backups/');
    define('DIR_FS_EMAIL_TEMPLATES'DIR_FS_CATALOG 'email/');
    define('DIR_FS_DOWNLOAD'DIR_FS_CATALOG 'download/');
    // define our database connection
    define('DB_TYPE''mysql');
    define('DB_PREFIX''zen_');
    define('DB_SERVER''');
    define('DB_SERVER_USERNAME''');
    define('DB_SERVER_PASSWORD''');
    define('DB_DATABASE''');
    define('USE_PCONNECT''false');
    define('STORE_SESSIONS''db');
    // use 'db' for best support, or '' for file-based storage
    7
    Well, since line 183 is likely the last line of the file, you most likely have extra blank lines or spaces at the end of the file, after the closing ?>
    The rest of the PHP syntax looks fine. I'm a little surprised to see that you've chosen to manually edit the dist-configure.php file directly instead of letting the installer build your configure.php files for you. But, naturally, you can use whatever approach you like as long as it works.
    I recommend getting rid of the double-spacing in the file though ... that's most likely what's caused you the headache in the first place.
    Aug 2008
    that is the way the lines were after the install, only files i edited were the includes config and the admin/includes config. i will fix the files and try it ...i appreciate your help.
    Chuck
  1. v151 SSL / Not working, having to logn back in admin, every page refresh
    By Fearless Freap in forum General Questions
    Last Post: 30 Jul 2014, 07:14 PM
  2. Replies: 5
    Last Post: 23 Jun 2010, 12:39 AM
  3. Admin SSL not working!
    By helpme in forum Basic Configuration
    Last Post: 27 Aug 2007, 03:58 PM
  4. Admin SSL not working??
    By styledata in forum Basic Configuration
    Last Post: 27 Jan 2007, 11:00 PM
