Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
  1. #51
    Dec 2009
    Canada
    Default Re: Canada Post Letter Rates
    I just wanted to say THANK YOU for your patience and pursue to help fellow zenners understand and solve the situation.
    I made the following changes and it worked!
    Quote Originally Posted by Royal View Post
    Hello Shanon,
    I'm sorry that you are still having problems. Please check post 24 and check to see if everything setup correctly.
    Login into your Zen Cart admin. Go to Configuration and click on Shipping/Packaging. Set these two lines to zero "0" if you didn't do so already. Like I have it in the attachment below.
    Quote Originally Posted by dal2009 View Post
    IT WORKS!!!! Here was the problem after countless hours of checking everything, hopefully this post saves a lot of people time. Letter Mail for what ever reason will not work if your shipping estimator is in "Popup" mode. Once I switched it to "2= Display as Listing on Shopping Cart Page" inside of Config/shipping/packaging/Shipping Estimator Display Settings for Shopping Cart Everything works! Thank You Royal for your help and time, it was reviewing your website that made me change my display settings.
  2. #52
    Jun 2008
    Canada
    Quote Originally Posted by dimsumgurl View Post
    You are very welcome!
    Pre-Owned Books and Second Hand Stuff: http://www.onlineyardsale.ca
  3. #53
    I have set up the CPC module and rates at CPC like the examples in this topic and still can't get this to work, one thing i was wondering though is wether the letter rate works with version 1.5? I do get the proper Expedited parcel rates although it seems to take a little long to get the rate from CPC but can't seem to get the letter mail.
    Kudos to all the wonderful replies in this forum.
    Thanks in advance
  4. #54
    Never mind, got it LOL I did find that with the Shipping Estimator Display Settings for Shopping Cart set to "2" when ever a product was added it took a while to add it and also for the view shopping cart to show because it would get the shipping rate everytime from CPC i changed it to "1" for the pop up function and the lettermail still shows ...... Pfffffff thanks to all the good tips :)
  5. #55
    Feb 2008
    Your length, width and height also must be given in the correct sequence.
  6. #56
    Jun 2006
    My client only wants to offer a Canada Post option if the delivery address is a PO Box. Is there any way to restrict this module as such?
    Many thanks!
  7. #57
    I am installing the CPC in V1.5 and have a small issue
    In the collect_info.php there is a line " <td class="main"><?php echo zen_image(DIR_WS_CATALOG_LANGUAGES . $languages[$i]['directory'] . '/images/' . $languages[$i]['image'], $languages[$i]['name']) . '&nbsp;' . zen_draw_input_field('products_name[' . $languages[$i]['id'] . ']', (isset($products_name[$languages[$i]['id']]) ? htmlspecialchars(stripslashes($products_name[$languages[$i]['id']]), ENT_COMPAT, CHARSET, TRUE) : htmlspecialchars(zen_get_products_name($pInfo->products_id, $languages[$i]['id']), ENT_COMPAT, CHARSET, TRUE)), zen_set_field_length(TABLE_PRODUCTS_DESCRIPTION, 'products_name')); ?></td> "
    I am also installing the CEON URI rewrite and they have this line in the collect_info.php
    " <td class="main"><?php echo zen_image(DIR_WS_CATALOG_LANGUAGES . $languages[$i]['directory'] . '/images/' . $languages[$i]['image'], $languages[$i]['name']) . '&nbsp;' . zen_draw_input_field('products_name[' . $languages[$i]['id'] . ']', htmlspecialchars(isset($products_name[$languages[$i]['id']]) ? stripslashes($products_name[$languages[$i]['id']]) : zen_get_products_name($pInfo->products_id, $languages[$i]['id']), ENT_COMPAT, CHARSET, TRUE), zen_set_field_length(TABLE_PRODUCTS_DESCRIPTION, 'products_name')); ?></td> "
    I am just wondering which way i should go with this. I have contacted the maker of Ceon URI Mapping (SEO) and his reply was
    " The Ceon files change ONLY the three wee blocks in a *standard* Zen Cart file, so they are the closest to the originals. I don't know what the Canada post ones are based on.
    You can copy the differences from the Canada post one to the Ceon modified one or the Ceon blocks to the Canada post file. "
    There are 4 collect_info.php files in the CPC add on where this occurs. Since CPC does calculations i am just wondering if i should change the lines to this since i have already installed the CEON add on.
    Does anybody know how to handle that ?
  1. v150 Canada Post Module Not Returning Rates for me
    By DJLQD in forum Addon Shipping Modules
    Last Post: 15 Jun 2012, 06:03 AM
  2. Canada Post vs letter mail
    By cwright in forum Addon Shipping Modules
    Last Post: 6 Sep 2008, 01:04 AM
  3. Canada Post rates on check out
    By sherman in forum Built-in Shipping and Payment Modules
    Last Post: 6 Apr 2008, 03:58 AM
  4. Canada Post differences in rates
    By redk in forum Built-in Shipping and Payment Modules
    Last Post: 11 Apr 2007, 08:09 PM
  5. USPS api rates: All foreign and domestic rates correct except for Airmail Letter Post
    By dharma in forum Built-in Shipping and Payment Modules
    Last Post: 23 Nov 2006, 02:57 AM
