Originally Posted by karimm It this because the script is not compatible with my sql version ? I use mysql 4.1.22 PHP 5.2.11 Any suggestions ? Yep, it's my mistake. FULL keyword is supported from 5.0.2. I'll patch the bug asap.
data_digger, Query Cache v1.7-beta for ZC 1.3.9h Reduce query count by 80% | Randomized Tests www.data-diggers.com
Originally Posted by data_digger Yep, it's my mistake. FULL keyword is supported from 5.0.2. I'll patch the bug asap. Hello DataDigger, Did you managed to patch it ? i would really like to use this. Thanks,
Forum Rules
