1. If you intend to use AIM, you need to have an SSL certificate set up so you can accept secure transactions on your site. Otherwise if you collect CC numbers without SSL protection you subject you and your customers to fraud and theft problems.
But not having SSL isn't going to give that particular error.
Yes i do have a SSL install to the cart
2. In your Authorize.net account, there is a page which allows you to set a transaction "delimiter" and maybe even an "encapsulation" character. What do you have those set to presently? I think v1.3.5 expects the Delimiter to be a comma, and the encapsulation to be blank.
I really am not sure where it is in my authorize.net net account this is at, but i did find a Direct Response Delimiter and it's set to no. i set it to yesusing the character set you specified above and it still did work
3. Do you have an "authorizenet" table in your database? If you do, then it's possible you might be able to get some debug response data from the records in it. If not, things get more complicated. Upgrading would be advisable.
Yes i do have an authorize.net table in my database, but it appears to be empty.
What else can i do. i would love to upgrade but it does work for me. i have tries in the past and it messed up other page on the website. Our current host only supports php4 and MySQL4. So upgrade would be an even more headache.
