[FONT=Calibri]I’m trying to upgrade my zencart 1.3.6 to the newest version. So far I have failed in every attempt. My biggest problem is data transfer. This is what I did:[/FONT]
[FONT=Calibri]Approach I (basically following the instruction)[/FONT]
[FONT=Calibri]Download and then upload the latest version, create a new database, edit both configure.php files to point to the server with correct userid and password, export data in a sql file from the existing db and import to the new db, and then [/FONT][FONT=Verdana]using a browser, surf to [/FONT][FONT=Default Monospace,Courier New,Courier,monospace]/zc_install/index.php. This is what I got:[/FONT]
[FONT=Times New Roman]1146 Table 'store2009.products_discount_quantity' doesn't exist
in:
[show fields from products_discount_quantity][/FONT]
[FONT=Calibri][/FONT]
[FONT=Calibri]Approach II[/FONT]
[FONT=Calibri]Download and then upload the latest version, create a new database, install a new cart, export data in a sql file from the existing db and import to the new db, run the installer again, choosing “upgrade”. In the end I could get nowhere. [/FONT]
[FONT=Calibri]I don’t know where I did wrong. Could somebody tell me if there’s a simpler way just to transfer data from one db to another?[/FONT]
[FONT=Calibri]Thank you in advance. [/FONT]
