Hi folks,
I found a download link: https://www.zen-cart.com/downloads.php?do=file&id=2138
Dan
Hi folks,
Dan
Hi Dan here you go I downloaded this from Dreamscape a week or two back - hope its the one you are looking for.
PM me if you have any problems :)
I'm currently lost in trying get Dreamscape's MZMT & Zen Cart's Zone Rates Shipping Modules working properly.
No matter what I've done, the output (when customers check out) of MZMT look like this:
Ground (0 x 0.00g) $0.31
Second Day (0 x 0.00g) $0.31
Next Day (0 x 0.00g) $0.31
($0.31 is the handling fee i've set up in admin, so the module found no product and its weight in shopping cart)
(I've configured the products_weight and the figures in shipping table properly, or it's what I thought, at least)
Zones rates module seem to have the same problem.
Any ideas to solve this? pls help. My zen cart version is 1.3.0.1
Thanks you in advance
I supposed my previous post didn't appear on support forum.
So, I make a reply to my own post hoping that it would solve the problem and a person with the answer will see my thread.
P.S I've made this post a day before in a forum that seem to be dead and can't figure out how to close it. So, pls don't blame me to be a double-posting rascal. Thanks.
Hi if you would like to PM me I will try and help you sort this problem out - as I have now finally managed to get mine to work as I want.Originally Posted by langtu123
Please make your posts public so that it will benefit the rest of the community. Thanks!
Here is my altered MultiGeoZone 1.000 for use in the UK. Please be aware that the two sql scripts will probably need to be altered as they are designed for my own installation. Hopefully it will help others out - also please remember that the original MultiGeoZone mod was created by its author and not me - I have just altered it for my own use.Originally Posted by Kim
Thank you all for helping me with the problem I've got, especially jayson.gurney.
I'm trying your mod and will refer to you soon if I can finally make it work as wanted.
Best regards,
