I didnt edit it? I wouldnt have a clue. So, I cant say for sure.
If the file has no line-breaks, then it's very possible that it's not getting executed because it probably has a double-slash in it for comments someplace, and thus everything after that is getting skipped, which would explain all the problems.
I'm not sure what software you're using to unzip, or to edit, or to upload/FTP, or to download/FTP, or to view files on your server. But something's bad.
And if it's treating ALL your files like that, then you're certainly going to have problems all over your site.
Which file is correct? The one I posted above with line breaks or this one:
The reason I am asking is,if I open this file on either my working site or my test site on a different pc, this is the exact code I see. But the code I pasted earlier is what I see on the working site or the test site using my new pc.. so, either way, the code is the same? Im really confused at this time!!Code:<?php /** * counter.php * * @package general * @copyright Copyright 2003-2009 Zen Cart Development Team * @copyright Portions Copyright 2003 osCommerce * @license http://www.zen-cart.com/license/2_0.txt GNU Public License V2.0 * @version $Id: counter.php 16091 2010-04-27 21:46:02Z wilt $ * @private */ if (!defined('IS_ADMIN_FLAG')) { die('Illegal Access'); } if (isset($_SESSION['session_counter']) && $_SESSION['session_counter'] == true) { $session_counter = 0; } else { $session_counter = 1; $_SESSION['session_counter'] = true; } $date_now = date('Ymd'); $counter_query = "select startdate, counter, session_counter from " . TABLE_COUNTER_HISTORY . " where startdate='" . $date_now . "'"; $counter = $db->Execute($counter_query); $sql = "INSERT IGNORE INTO " . TABLE_COUNTER_HISTORY . " (startdate, counter, session_counter) values ('" . $date_now . "', '1', '1')"; $db->Execute($sql); $sql = "SELECT * FROM " . TABLE_COUNTER_HISTORY . " WHERE startdate = '" . $date_now . "' AND counter = 1 AND session_counter = 1 LIMIT 1"; $result = $db->execute($sql); if ($result->recordCount() <=0 || $counter->RecordCount() > 0 ) { $counter_startdate = $counter->fields['startdate']; $counter_now = ($counter->fields['counter'] + 1); $session_counter_now = ($counter->fields['session_counter'] + $session_counter); $sql = "update " . TABLE_COUNTER_HISTORY . " set counter = '" . $counter_now . "', session_counter ='" . $session_counter_now . "' where startdate='" . $date_now . "'"; $db->Execute($sql); } $counter_query = "select startdate, counter from " . TABLE_COUNTER; $counter = $db->Execute($counter_query); if ($counter->RecordCount() <= 0) { $date_now = date('Ymd'); $sql = "insert into " . TABLE_COUNTER . " (startdate, counter) values ('" . $date_now . "', '1')"; $db->Execute($sql); $counter_startdate = $date_now; $counter_now = 1; } else { $counter_startdate = $counter->fields['startdate']; $counter_now = ($counter->fields['counter'] + 1); $sql = "update " . TABLE_COUNTER . " set counter = '" . $counter_now . "'"; $db->Execute($sql); } $counter_startdate_formatted = strftime(DATE_FORMAT_LONG, mktime(0, 0, 0, substr($counter_startdate, 4, 2), substr($counter_startdate, -2), substr($counter_startdate, 0, 4)));
UPDATE - I just checked on my new laptop, the same file in Adobe Dreamweaver and in Macromedia Dreamweaver, and Macromedia dreamweaver shows the exact code as this message. So, if this code is correct, then it isnt the file that is wrong? But, I must have a setting off in Adobe... yet that wont remedy the problem with the counter...
Also, I have gone through all of the files again, using winmerge and am ready to try this again. So, what I plan to do, is delete all the files on my test site and reupload everything... do I need to upload the install files? My database is at 1.3.9c now?
If the file *on the server* doesn't have the requisite line-breaks, then you're going to have problems. It doesn't matter what it looks like on your PC. It's the server that matters. If your dreamweaver app is breaking the files as it uploads them (common problem with dw), then that may be your culprit.
Dreamweaver's FTP is sketchy at best, both windoze and mac versions.
Since your database is already updated, you don't need the zc_install steps.
Im pretty certain the line breaks are there. It is only in the adobe program that I see it incorrectly.
Typically I use an ftp program like wsftp995 to load all of the files. However it seems like I have to go back and reload the images because they are distorted from not loading as a binary..
Hey, I wanted to let you know what I have now:
Ok, here on my test site... I have 3 directories:
first directory:
all looks the public side...
but in the admin I get the internal server error.
second directory:
I have a new zen cart set up in there that has no changes and it is fully functioning.
Third Directory
Then I have another one... which I have tried to upgrade the database to and connect it to her database, and I have the public side working, with her products showing in there... (images arent because I didnt load them)
but the admin gives me this info (*note, I have checked the configure.php files and couldnt see anything I had wrong, but that doesnt mean it isnt wrong... it just means I have looked at it too many times! I have also ran the install twice, to doublecheck and it says there are no upgrades needed.) :
Hello. Thank you for loading Zen Cart™.
You are seeing this page for one or more reasons:
1.This is your first time using Zen Cart™ and you haven't yet completed the normal Installation procedure.
If this is the case for you, you will need to upload the "zc_install" folder using your FTP program, and then run zc_install/index.php via your browser (or reload this page to see a link to it).
2.Your /includes/configure.php and/or /admin/includes/configure.php file contains invalid path information and/or invalid database-connection information.
If you recently edited your configure.php files for any reason, or maybe moved your site to a different folder or different server, then you'll need to review and update all your settings to the correct values for your server.
See the Online FAQ and Tutorials area on the Zen Cart™ website for assistance.
To begin installation ...
1.The Installation Documentation can be read by clicking here: Documentation
2.You will need to upload the "zc_install" folder using your FTP program, and then run zc_install/index.php via your browser (or reload this page to see a link to it).
3.The Online FAQ and Tutorials area on the Zen Cart™ website will also be of value if you run into difficulties.
Copyright © 2003-2010 Zen Cart™
Anyone? I have gone through any threads I can find on internal server errors, and nothing has been successful, ran the install again just in case? nothing...
On the setup one, I have gone through the configure.php files til I am blue in the face and crosseyed... nothing there I can find.. ran the fix_cache_key and no luck.
Even a hint would be helpful of where to fix this. I cant move on to anything else with this holding over my head!
Here is my configure.php file from includes/
* @package Configuration Settings circa 1.3.8
* @copyright Copyright 2003-2007 Zen Cart Development Team
define('HTTP_SERVER', 'http://mydomain.com');
define('HTTPS_SERVER', 'https://mydomain.com');
define('DIR_WS_CATALOG', '/babysewcute/');
define('DIR_WS_HTTPS_CATALOG', '/babysewcute/');
define('DIR_WS_PHPBB', '/');
define('DIR_FS_CATALOG', '/home/wahmcoup/public_html/babysewcute/');
define('DB_TYPE', 'mysql');
define('DB_PREFIX', 'zen_');
define('DB_SERVER_USERNAME', 'wahmcoup_XXXXXX');
define('DB_SERVER_PASSWORD', 'XXXXXX);
define('DB_DATABASE', 'wahmcoup_XXXXXX');
define('STORE_SESSIONS', 'db'); // use 'db' for best support, or '' for file-based storage
define('DIR_FS_SQL_CACHE', '/home/wahmcoup/public_html/babysewcute/cache');
// EOF
my /admin/includes/configure.php (yes, it's actually correctly renamed)
/*************** NOTE: This file is similar, but DIFFERENT from the "store" version of configure.php. ***********/
// Main webserver: eg-http://www.your_domain.com -
// HTTP_CATALOG_SERVER is your Main webserver: eg-http://www.your_domain.com
// HTTPS_CATALOG_SERVER is your Secure webserver: eg-https://www.your_domain.com
* If you desire your *entire* admin to be SSL-protected, make sure you use a "https:" URL for all 4 of the following:
define('HTTP_SERVER', 'http://mysite.com');
define('HTTPS_SERVER', 'https://mysite.com');
define('HTTP_CATALOG_SERVER', 'http://mysite.com');
define('HTTPS_CATALOG_SERVER', 'https://mysite.com');
define('DIR_WS_ADMIN', '/babysewcute/admin/');
define('DIR_WS_HTTPS_ADMIN', '/babysewcute/admin/');
define('DIR_FS_ADMIN', '/home/wahmcoup/public_html/babysewcute/admin/');
define('DB_SERVER_PASSWORD', 'XXXXXX');
// EOF
Ignore this for now, I Am so tired I dont know what I did if someone else ran into the problem, but I think I have it fixed in one of the directories. 1.3.9d ... I have to put in the custom files and I think I have it! Will let you know if so.
