You own a secure certificate for:
www.cindyscinnamon.com
So you should use it for your site ...
Currently, you are using:
cindyscinnamon.com
for your non-secure pages ...
For your secure pages ... you are using a "shared" certificate:
https://secure.blurhost.com/~loginame
But you should use the one you own ...
https://cindyscinnamon.com
Now if you have problems when set to your secure certificate as:
You should change the references for ALL the HTTP_SERVER and HTTPS_SERVER settings to:
So your admin would either be:
Or you would use:define('HTTP_SERVER', 'http://cindyscinnamon.com');
define('HTTPS_SERVER', 'https://cindyscinnamon.com');
define('HTTP_CATALOG_SERVER', 'http://cindyscinnamon.com');
define('HTTPS_CATALOG_SERVER', 'https://cindyscinnamon.com');
For your store you would use either:define('HTTP_SERVER', 'http://www.cindyscinnamon.com');
define('HTTPS_SERVER', 'https://www.cindyscinnamon.com');
define('HTTP_CATALOG_SERVER', 'http://www.cindyscinnamon.com');
define('HTTPS_CATALOG_SERVER', 'https://www.cindyscinnamon.com');
